Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    Protodie- XTC buggy, chop, cut ,rebuild
    S.W. Michigan
    Most of my projects are all new design & build from the ground up.
    This log is about a customers buggy that we chop cut rebuilt.
    Customer brought us a XTC 2 seat buggy that he wanted us to redesign & build to put our GSXR 1000 / RPM gear box engine cradle, A arms , Fox shocks, rear wheel kits ,,,etc...
    This buggy had very little travel,,,,and the front A arms are scary small:IMO
    Here is the buggy before
    Re: Protodie- XTC buggy, chop, cut ,rebuild
    S.W. Michigan
    So I brought it in to the shop & started re-creating the chassis in 3D CAD to start the design process.
    Once I have all the main chassis points re-created in CAD, then I merge in our existing designs and components, E cradle RPM, A arms, suspension,,,etc.
    currently working on the rear only
    S.W. Michigan
    Got the rear designed,,,,,,,,,,,,time to start cutting.
    Kinda fun for a change,,,since I normally build from scratch
    S.W. Michigan
    Customer very happy with the rear design & work,,,,,,,,,,,,,so we move on to the front and start to design
    Sep 2006
    Groves, Texas
    He's gonna be really happy when it's done.He'll be totally amazed at the difference won't he!
    Thats one hell of a shop you have....... All I can say is "Jealous!!"
    One day I will be to that level.... one day
    I like the buggy and LOVE your shop!
    Nice job.
    S.W. Michigan
    Thanks Guys
    He stops in every week & ,yes is very happy.
    This buggy will be lighter than ours, as it is mostly just for dunes & not racing,,,,,,,,,,,,,only with the same parts & performance so it should scream quite nicely in the dunes.
    alright ,,,,,,,,,,,,,,,design done, start cutting off all the front components and grinding
    he wanted to keep his fuel cell. There is room for one of ours later if needed
    S.W. Michigan
    Front has 17" of travel and uses our single seat lower A arm. Upper A arm had to be lengthened to achieve proper suspension geometry & performance.
    Rack was extended and extra guide & supports were added to achieve zero bump steer.
    Using shock mock up tubes set for full droop and full compresion.
    This allows me to use the shock to control the limits of suspension
    Nice Work Jody!
    CRASH!!! GAME OVER!!!!!
    INSERT COIN!!!!!
    http://www.jdmpooldesign.com
  1. My custom mini buggy (similar to panther)
    By andy777bmx in forum Projects in Progress
    Last Post: 12-19-2011, 10:36 PM
  2. How Much for that Buggy in the Window?
    By darwinpayne2000 in forum MiniBuggy.net Lounge!
    Last Post: 03-11-2010, 09:30 PM
  3. buggy terms? street legal buggy need to find pic inside
    Last Post: 02-08-2009, 09:11 AM
  4. First time buggy builder
    By ReinIse in forum Show off your toys in here!
    Last Post: 05-14-2006, 05:03 PM
  5. I'm a first time buggy builder
    By ReinIse in forum Projects in Progress
    Last Post: 05-10-2006, 08:07 PM
