Thread: Greetings all
Results 1 to 8 of 8
    Greetings all
    Introduction time, I'm from Maryland, the younge age of 18, been fabricating for about 5 years now, welding, lathe mill ect... done a few wheeler projects and gathering parts for my first buggy build. Also pretty good with cad, good enough to land a job over the summer designing. Looking forward to talking with fellow builders.
    Sent from my SM-G950U1 using Tapatalk
    Re: Greetings all
    Oct 2009
    Welcome to MiniBuggy
    Re: Greetings all
    Oct 2017
    Peace River Alberta Canada
    Welcome aboard, following plans or designing it yourself? I’m sure all the picture junkies are johnsin for a hit, post up some of your ideas.
    Re: Greetings all
    Sep 2005
    Pacific Northwest
    Welcome! These buggies are a ton of fun to build and to drive. Good luck on your project. Start a build thread and bring us along with your adventure.
    Re: Greetings all
    Senior Member jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Wow not a bad skill set for 18. This guy's going places.
    Re: Greetings all
    Here is what I'm currently working on designs for, the frame and motor with mounts is drawn up in solid works and I'm just working on suspension geometr. I have my tubing bender ready to go, just need to purchance the tubing. It's a gsxr1000 powered rig, uses a Volvo m45 transmission, the engine is mounted inline with the front of the buggy. So the output of the engine is facing the back of the seats, and I'll run a shaft to the transmission. The front and back differentials will be linked with a driveshaft, which will have a sprocket on it. So the output of the transmission will also have a sprocket. And then chain link, I'll start and thread and show me drawings and it may make more sense. This will be a 2 seater for offroading, riding the bikes on the powerlines is a killer, I'd like to join the rzr crowd but I like built over bought. (Photos are my inspiration)
    Re: Greetings all
    Welcome to the madness.
    Sounds like you have a solid skill set - congrats on that. As stated, start up a build thread and share away.
    Chains - make sure you get advise from the members running them. Done right they’re a good, reliable power transfer component. Done wrong they’re a constant headache. I’m sure you’ll get the info needed to make them work.
    Design - figure out tire size first and work your way in. Most want to start with a chassis design and work out but it’ll work better designing your suspension first, figuring where it attaches to the chassis and then designing the chassis around those points.
    Re: Greetings all
    Thanks for the advice and kind words, I'll link the build thread. I'm probably going 32" tires somewhere between 28-32 for sure, I already have some suspension done up and I was able to get some good info on a setup like this(pic below).
