When I got my buggy the suspension was mounted almost backwards. Is this OK? Can I leave it like this? Or should I redesign the whole rear suspension
Results 1 to 10 of 10
01-12-2021 05:50 PM
01-12-2021 07:22 PM
I would redo the upper shock mounts. But other than that I would run it till something breaks.
01-12-2021 08:02 PM
If I redid the upper shock mounts is the angle of the shocks ok?
01-12-2021 10:15 PM
You can make it right when you redo the upper mount. You will need to cycle it to see where it needs to be.
01-13-2021 11:31 AM
I agree, the rear suspension needs to be redone. Hands down. Take Photos every step of the way. We all learn through each other.
HARD WORK PAY$
01-13-2021 04:04 PM
For a dual a-arm suspension, you usually have the shocks pointing inwards, towards each other. I assume they are mounted that way because it provided a convenient mounting point. It probably works, but . . . it looks odd.
After you've been participating on this minibuggy site for a few years, you'll probably see everything. Or, at least you'll think you have. If it were me, I would redesign it and make it look more traditional. That way, when people look at your buggy, they'll say "Wow, that looks really cool!", instead of "Why did you mount the shocks that way?"
01-13-2021 07:07 PM
I have been learning lots about geometry of suspensions and steering setups. A rule of thumb is you want the bottom of the shock to be perpendicular to the A-arm at full bump. But it's not always possible. A similar rule of thumb applies for a rear swing arm setup.HARD WORK PAY$
01-15-2021 01:11 PM
Here are some pictures of mine as I was setting it up, hopefully these help.
CWI CWS CWE
Top mounted shock A-Arm
By cdnjaguar in forum Suspension - Wheels & TiresReplies: 6Last Post: 02-02-2015, 01:06 AM -
Kawasaki Prarie 600 mounted backwards?
By crazy in forum Motor - EngineReplies: 0Last Post: 03-01-2012, 12:16 PM -
Clutch Lever Mounted onto Shifter?
By uzrnaim in forum Controls and electricalReplies: 22Last Post: 09-27-2010, 10:50 AM -
R1 Mounted Differently
By ALWX65 in forum The UTV AreaReplies: 0Last Post: 11-05-2009, 07:54 PM -
anyone have pictures of how there gear box mounted???
By roostingrhino in forum DrivelineReplies: 8Last Post: 02-12-2008, 04:03 PM
