Results 1 to 6 of 6
    Frequency or %Droop - Spring rate selection
    Hi all.
    I want to select springs for my st-3.
    It seems to me that some of the people choose springs according to a desired natural frequency and some people choose springs according to the desired perceantage of droop and bump.
    It's rear to achieve both of them.
    Which is the prefered method and why?
    Thanks
    Re: Frequency or %Droop - Spring rate selection
    Frequently seems to be more road racing oriented. I’ve had it introduce to me and it reads like common core math. Makes no sense.
    Off road stuff tends to talk in rate instead. Set up for a drop of 45-60%, depending on terrain use and such.
    FOA has a spring calculator that seems to work quite well. I’m on an iPad, otherwise I’d give you a link. Search FOA Spring Rate Calculator
    Senior Member dangeranger93's Avatar
    Nov 2015
    Lawrenceburg IN
    The FOA calculator hasn't been working for me lately, not sure if its me or them
    * FOA did not worked for me as well but they give a link to another calc (exactly the same) which based on %drop and not frequency.
    As for frequency design goal - I got confused because as far as I know, specific frequency has specific static deflection which will not always satisfies desired drop.
    Lets say I want to have 1.5 Hz frequency. according to the formula marked below I will always have a static deflection of 4.34".
    Now, for 16" wheel travel I will have about 25% drop but if I have 25" wheel travel I will have only 17" drop.
    Long travel suspension cannot satisfy both design goals.
    Is it correct?
    Forget frequency. Set your rate so that you have as close to zero preload possible.
    I don't know what happened to all the good spring calculators but all the ones I have seen lately are crap.
  1. Valving vs. spring rate
    By EvoMak in forum Suspension - Wheels & Tires
    Last Post: 12-03-2013, 06:13 PM
  2. Need help with my spring rate!
    By stpeter in forum Suspension - Wheels & Tires
    Last Post: 10-31-2013, 08:51 PM
  3. SAE Baja Buggy Spring Rate selection???
    By atomicjoe23 in forum Suspension - Wheels & Tires
    Last Post: 09-30-2009, 04:40 PM
  4. spring rate??
    By bshay20 in forum Suspension - Wheels & Tires
    Last Post: 01-01-2009, 08:31 PM
  5. spring rate
    By enroffroad in forum Suspension - Wheels & Tires
    Last Post: 11-29-2007, 03:40 PM
