Results 1 to 10 of 13
    Spring weights flipped
    Mar 2018
    Central Ohio
    On a dual rate set up. What would be the advantage to putting the heavier spring in the top position and the lighter spring in the lower position?
    This configuration is recommended by Elka for the front end of my buggy and I am trying to understand the benefits / reason for doing this.
    Thoughts?
    Re: Spring weights flipped
    Same length springs?
    Do you have adjustable cross over rings on the shock bodies? If so that would be a no. You’ll lock out the heavier rate spring during heavy compression if you do.
    Sep 2014
    West Palm Beach FL
    Admittedly I'm completely uneducated on the subject, but I can't even see how it would make a difference at all? I mean the softer part of the spring will compress easier than the stiffer part no matter where it is, right?
    Sep 2014
    West Palm Beach FL
    I could see it being an issue if one spring is too short to be on the bottom. I would think that would be an obvious problem though. Like if it didn't reach far enough up on the shock body.
    I would think the softer spring would be on the bottom, just to lessen the amount of movement of the spring that slides up and down on the shock body? Just an uneducated guess though.
    Cant really tell from the image. That crossover setting has my mind spinning..lol
    Sep 2014
    West Palm Beach FL
    OK I think I got my mind wrapped around it...lol Like Kfab already said, I think you put the soft part up top, so when you reach the crossover, it will eliminate the soft spring and only rely on the stiffer bottom spring. Without the cross over setting, I don't think it would matter which spring was on top or bottom.
    Sep 2014
    West Palm Beach FL
    The only way I can see it making sense the other way around, is if the two springs together are softer than the one ''soft'' spring alone. Which I guess is a possibility, because there are twice as many coils.
    You can thank me for not helping at all..lol I will shut up now and hope you two work it out.
    Mar 2018
    Central Ohio
    [QUOTE]
    Springs are different lengths. Bottom spring is 12" x 125# and the top spring is 8" x 150#. Travel is 10"
    Yes that crossed my mind and is the part that's not making any sense to me...lol
    I'm wondering if it has to do with the higher than normal unsprung weight.
    Sep 2014
    West Palm Beach FL
    I know I said I was gonna shut up lol , but it looks like you answered your own question. If the travel is 10'' and the short spring is 8'' then it couldn't be on the bottom. It wouldn't reach the shock body where the two springs meet.
    And I think I might be on the right track with the two springs acting together, they may be softer than with the one spring locked out.
    If you have a separator and a cross over collar, soft on top, no question.
    8 & 12 lengths - shorty on top. Id ignore Elka on this one.
    Yes, to a point. Bottom part of the page explains it. http://yellowdogracing.com/springs.htm
    125 lb and 150 lb/inch spring combo gives you an effective rate of 68 lb/inch at the beginning of the stroke.
    Depending on which spring you consider your main, you would jump up to a 125 lb/inch, or a 150lb/inch once the crossover collar is contacted.
    Too much main spring can cause pogo problems, but it can be bandaided with adjustments to the cross over. Either of those should be fine, though, and since your 8 inch spring is too short to act as the main, leave the 12 as your main.
  1. FL400 flipped...Need help/suggestions
    By fns in forum Honda's Pilot & Odyssey
    Last Post: 05-05-2016, 11:20 AM
  2. Tire Weights
    By AtvNut in forum Suspension - Wheels & Tires
    Last Post: 07-06-2011, 09:12 AM
  3. Car weights?
    By NWOff-Roader in forum MiniBuggy.net Lounge!
    Last Post: 04-20-2009, 12:07 PM
  4. Engine Weights
    By s27sam in forum Motor - Engine
    Last Post: 04-08-2009, 03:53 PM
  5. Corner Weights
    By MongooseGSXR750 in forum Suspension - Wheels & Tires
    Last Post: 12-03-2007, 02:55 AM
