Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: Spring weights flipped
    Forgot to add, but if your main spring rate is too low, you will run out of crossover adjustment, and end up binding the coils before you can achieve enough force.
    Thanks for all the feedback. I have been rolling this around in my head trying to come up with a logical reason for it. The only thing I came up with is...
    A way to address the nose dive from braking, high COG, Forward body roll in general.
    Two other things came to mind. 1) this set up was done 10 years ago, maybe the industry as a whole looked at things differently then. It was also for dune riding, and I am not familiar with that type of set up.
    With a shorter tender there is no logic. Bad info, instead.
  1. FL400 flipped...Need help/suggestions
    By fns in forum Honda's Pilot & Odyssey
    Last Post: 05-05-2016, 10:20 AM
  2. Tire Weights
    By AtvNut in forum Suspension - Wheels & Tires
    Last Post: 07-06-2011, 08:12 AM
  3. Car weights?
    By NWOff-Roader in forum MiniBuggy.net Lounge!
    Last Post: 04-20-2009, 11:07 AM
  4. Engine Weights
    By s27sam in forum Motor - Engine
    Last Post: 04-08-2009, 02:53 PM
  5. Corner Weights
    By MongooseGSXR750 in forum Suspension - Wheels & Tires
    Last Post: 12-03-2007, 01:55 AM
