Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
    Re: Heim joint vs Johnny Joint?
    Blog Entries
    1
    Is there a great alternative for heim joints to accomplish the same articulation and similar strength?
    Not really.
    Even though I prefer Auroras, I buy FKs as that is what most misalignment's are made to fit. Takes a lot of the guess work out of it.
    I am looking to do a similar project - what size of heim joint is recommended, and who is a good supplier?
    Sep 2017
    Lincoln, Nebraska
    I'm going to be looking at half inch heim joints for mine. Think I'll run 2 on each J-arm and trailing arm for mine, spaced about an inch apart. Then run a grade 5 bolt through them. Since I'm looking at running either a Honda Rebel 234cc (Rebel 250 engine), Lifan 200cc, I should be fine strength wise. I may go with double a-arms all around in a revision build, but I want to see what I can do with this setup first.
    if your working on a side by side (SXS) what size would you use? I know it's a loaded question so maybe I'll rephrase it; How big is too big and how small would be too small?
    And as a followup question, what manufacturer/brand/type will give me the best articulation?
    Blog Entries
    1
    Quote Originally Posted by 67StingrayJ View Post
    Hiems or Johny joints? Most JJ's articlulate about the same which is pretty poor. They get about 40* total movement.
    Pro-am has about the most angular movement for high misalignment spacers in hiems. Depending on the size, they can go up to 37* each direction.
    Sep 2017
    Lincoln, Nebraska
    If it is Heim joints he's asking about, what is the ideal size?
    For myself I picked up a 4 pack (will be getting several more) of chromoly heim joints from Amazon they are 1/2" with 1/2x20 thread. $30 for them. Granted I'm not doing a SXS just a single seater, but I felt like those are more than adequate for the front suspension and rear trailing arms.
    For side by side, I'd think maybe 5/8" minimum.
    sounds like solid reasoning to me. Any recommendations as far as manufacturer? How about part numbers? I would ask for a link but some poor sap 5 years from now is going to be asking the same thing and all he'll have is broken link. Your welcome future user!
    Sep 2017
    Lincoln, Nebraska
    So the ones I have are American Star 4130 Chromoly 1/2" XMR8 heim joints.
    The 5/8" heim joints are American Star XML8-10.
    http://www.amstarmanufacturing.com/RodEnds.html
  1. Rose/Heim joint adjustment
    By tbwcurtis in forum Suspension - Wheels & Tires
    Last Post: 10-31-2012, 02:31 PM
  2. Heim/rose joint problem
    By LEE1969GB in forum Suspension - Wheels & Tires
    Last Post: 11-14-2011, 05:04 PM
  3. heim joint question
    By andy777bmx in forum Suspension - Wheels & Tires
    Last Post: 02-07-2010, 09:46 AM
  4. Heim joint angle?
    By CARLRIDDLE in forum Suspension - Wheels & Tires
    Last Post: 03-19-2008, 01:51 PM
  5. Heim joint questions
    By Mike in forum Suspension - Wheels & Tires
    Last Post: 11-07-2006, 03:27 PM
