Results 1 to 9 of 9
    FOX AIR 2.0 with remote reservoir
    Nov 2008
    Australia. V IC
    Hi All
    If i removed the Valve fitting from the top of a FOX Air 2.0 10" and fitted a Remote reservoir to it......would it still work as an air shock or would the modification create too much of a restriction?
    Re: FOX AIR 2.0 with remote reservoir
    Blog Entries
    1
    Resi out the top does not do much for a airshock, to much shaft displacement. Resi out the bottom with a large feed tube will work wonders.
    Nov 2008
    Australia. V IC
    Thanks bdkw1
    What size feed tube and resi would you recomend for a fox 2.0 10" shock?
    Blog Entries
    1
    1/2". Resi needs to be about 2/3's the length of the shock can.
    Nov 2008
    Australia. V IC
    Awsome, thanks bdkw1
    Blog Entries
    1
    Be warned, if you go resi out the bottom you will have to really soften up the valving. With the additional fluid flow through the piston you will have almost double the damping that you had before.
    Nov 2008
    Australia. V IC
    makes sense, no nitro/oil mush mix........i will take note of that
    Blog Entries
    1
    It's not just the air/oil mix. Shaft displacement is huge on a air shock. When you figure it shaft displacement your effective piston area is only 1.91 square inches. With resi out the bottom all the oil must go through the piston making you working area 3.14.
    If you wanted to get real tricky, you could put the resi outlet a couple inches from the top. This would give you a 65% increase in damping as the piston went by the port. Bump zone for free. Walker shocks use this trick.
    Nov 2008
    Australia. V IC
    mmmm...interesting, i might stick to the Resi out bottom as first suggested
  1. Dual Reservoir CNC Brake Pedal Assembly
    By K-fab in forum For Sale
    Last Post: 05-30-2018, 01:35 PM
  2. fox shocks with remote reservoir
    By fns in forum For Sale
    Last Post: 10-25-2014, 02:44 PM
  3. To Reservoir on not to Reservoir
    By foggy in forum Suspension - Wheels & Tires
    Last Post: 02-13-2013, 09:30 AM
  4. piggy back or remote reservoir shocks
    By tbwcurtis in forum Suspension - Wheels & Tires
    Last Post: 11-05-2012, 09:49 AM
  5. Ecotec Remote Oil Filter
    By diirk in forum Motor - Engine
    Last Post: 04-09-2011, 10:23 PM
