Results 1 to 3 of 3
    Rear geometry setup. Camber and toe.
    Senior Member jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Setup is a upper and lower control arm IRS with fixed rear axel.
    What is a base start for camber and toe in. I believe toe in help offset the understeer of the locked centre?
    Camber I'm not so sure on.
    Any thoughts?
    Re: Rear geometry setup. Camber and toe.
    Welcome to MBN.
    In the rear:
    Toe in helps the car come out of the corner
    Toe out helps the car turn into the corner
    It's just the opposite up front.
    With a locked rear (spool) zero to maybe an 1/8” of toe out will help with understeer.
    Camber - I like about a degree to 1.5 in the back at ride height. It will vary depending on how much scrub you build into the rear suspension as it cycles.
    Sep 2016
    Bendigo AUS
    Top stuff! I've got the weight distribution pretty "Ok". Fox 2.0 in the rear.
    Good stuff! Love the sig. Lol.
    800 for the fox shocks. doh!
  1. Rear camber problem help needed
    By Cruzebabuze in forum Projects in Progress
    Last Post: 08-22-2015, 10:56 AM
  2. Rear Suspension - Trailing Arm Geometry
    By jason_maverick in forum Suspension - Wheels & Tires
    Last Post: 10-25-2011, 11:56 AM
  3. rear end camber
    By jerry in forum Suspension - Wheels & Tires
    Last Post: 05-01-2008, 10:32 PM
  4. cv/ rear end setup- need help!!
    By nate in forum Driveline
    Last Post: 03-10-2008, 10:34 PM
  5. Rear Camber
    By KWiKSand in forum Suspension - Wheels & Tires
    Last Post: 11-17-2006, 07:18 PM
