Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
    Re: Air shocks and limit straps
    #21
    My thoughts are, insufficient oil let them rebound too fast. It also made the spring rate much more linear resulting in much more shaft pressure when fully extended. You may have also gotten some soft washers.
    Replace the washers, fill with a little extra oil for a more progressive spring rate and try again.
    #22
    Quote Originally Posted by CARLRIDDLE View Post
    Buddy runs kings and did a lot of work to make them right. Heres a write up he did on filling them;
    step 5.5.
    Let the pressure out of the resivoir. You want the IFP to move away from the top of the resi. Otherwise,
    it can top out durring use lowering the internal pressure and causing cavitation.
  1. limit strap mounts location
    By jjstime in forum Suspension - Wheels & Tires
    Last Post: 02-07-2014, 05:10 PM
  2. Driver size limit for Velociraptor
    By vegasloki in forum Badland Buggy Group
    Last Post: 08-15-2012, 08:26 PM
  3. bump stops and straps
    By bradurl in forum Suspension - Wheels & Tires
    Last Post: 05-03-2011, 08:09 AM
  4. Nylon straps?
    By fatal-exception in forum How To Do It
    Last Post: 05-12-2010, 07:42 AM
  5. Weight limit for Fox 2.0 Airs?
    By standfast in forum Suspension - Wheels & Tires
    Last Post: 10-26-2007, 07:37 PM
