Results 1 to 10 of 12
    front hub for combo spindle
    Apr 2009
    Boise, Idaho
    does any body know if wildwood or anyone makes a front hub that fits a combo spindle stub? i'm trying to find something that i can end up with 5 on 4.75 bolt pattern that will match my rear micro stub bearings. so i can have same bolt pattern and not use big wide 5 adapter plates.
    Re: front hub for combo spindle
    What wheels you gonna use in rear? The wide 5 adapters (alum ones) are 4.75 x 5 so a redrill of bearing hub or adapter will be required.
    But to answer you ??? No don't think I've seen a combo spindle with 4.75 pattern.
    Apr 2009
    Boise, Idaho
    Maybe I'll have to check that. I thought the micro stub bearings were 4.75. I have the big giant 33 spline micro stubs and the corresponding USA made bearing flanges. This project has been on hold for a while so my memory might be a little foggy
    I started my project with combo spindles and tried looking around for something other than 5x205, but didn't have any luck. There are adapters, but if your goal is just to have 4 wheels with the same bolt pattern it might be easiest to adapt the rears to 5x205 to match the readily available options for front combo spindle hubs.
    My micro stubs are 5x4.75". They came with the RaceTrim kit that also included an adapter to 5x205". http://www.mooreparts.com/race-trim-...b-disc-brakes/ I do remember there being a 2nd set of holes, so perhaps they were re-drilled for the kit, but they are 5x4.75"
    If you are set on 5x4.75, you could always modify the spindles to fit hubs a lot of the resto-mod guys use, but that kind of opens an entirely new can of worms.
    What are you doing for brakes? The nice thing about the available front combo kits is the brake setups are plenty, and pretty much plug and play.
    Sorry, yes microstub kits avail are 4.75 x 5. I'd run that latest rage alum adapter iflytii referenced and plenty of offroad or sand wheels for vw pattern. I bought them elsewhere for less, but that's been a few yrs.
    For a hub s10 has the same bolt pattern, or the Camaro has the same pattern, just a thought.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Quote Originally Posted by 98Blazer View Post
    On my first buggy I used 2000 Camaro front unit bearing hubs, 5 x 4 3/4. Four bolt flange mount, worked good, easy, cheap, replacement at any auto parts store.
    Isn't the hub for the big 33 spline shaft 5 x 4 1/2, Dodge Intrepid?
    The empi bearings are re-drilled from a 4.5" out to 4.75", not sure why they wouldn't keep them at 4.5", but it probably has to do with other people sourcing parts externally.
    They also remove all of the numbers from their bearings. I know because I blew one and had a hard time paying 180 bucks 2 years ago.
    Looks like they are 208 a piece on ebay, which is ridiculous.
    Apr 2009
    Boise, Idaho
    well it looks like the best way is to just stick to wide 5 and buy a common combo spindle front hub and rear adapters. I've spent hours looking through wilwood chevy front hub bearings and i cant find anything close to what i measured on my combo spindles.
    I used S-10 spindle snouts with 5 on 4.75" S-10 vented rotors. I fitted it with willwood
    brake calipers. You can find replacement wheel bearings, seals, and rotors and any local
    parts store. I was a very affordable set up.
    Project X
  1. Front upright & brake combo with s10 hubs
    By nofearmxer in forum Suspension - Wheels & Tires
    Last Post: 01-01-2017, 11:04 AM
  2. Dimensions for combo spindle snouts ????
    By Xcalibur in forum Suspension - Wheels & Tires
    Last Post: 10-13-2009, 08:57 PM
  3. Tatum Combo Front Hubs/Discs
    By standfast in forum File Library
    Last Post: 09-04-2008, 09:53 AM
  4. Combo Spindle Snout
    Last Post: 09-04-2008, 09:13 AM
  5. Street wheel/tire combo for 400 ex front hubs.
    By Montanaminirail in forum Suspension - Wheels & Tires
    Last Post: 02-15-2006, 09:11 AM
