Results 1 to 5 of 5
    issue with bolt pattern size on hub
    Cool
    I recently acquired a mini sand rail that was home built I have spent a lot of time fixing some of the frame issues and putting a zx11 engine in it now I am turning my attention to the suspension,braking and ride height. which brings me to my problem the front spindles are off a raptor no issue there but the rear hubs bolt pattern is throwing me its a 4 bolt pattern but seems to measure 123-124 mm no atv hub I can find matches that neither do any golf carts that I can find any idea about where these hubs cam from? the wheels have been dilled to fit this hub but I am trying to get a taller tire like 29-30 in tall and there aren't any atv utv tires in a 10 in wheel that have that size. but if the hub fts a car wheel It would make it easier to find attire that would fit my needs. I would rather not buy new wheels just to drill them out plus the geometry is never perfect and I would like to run this buggy on the highway. any suggestions would be great I am at a loss. plus the cheapest solution possible would be great to thx
    Re: issue with bolt pattern size on hub
    Unless its a home made hub. Seen Suzuki lt500 hubs used, plenty of Honda stuff too. Pic of the hub and stub/cv. Both sides, someone will prob recognize it.
    it doesn't look home made. I know I could use a lot of other hubs cause the shaft is a basic 1 in 24 spline then I need new hubs wheels and tires cost is around 600 I was hoping that if these hubs I have were some car bolt pattern I could for now just to get it rolling find some old tires and wheels for cheap that are about 6 in taller than the ones I have it sits way to low in the back also having trouble getting pics on here I think I need to shrink them thx
    Check this link.
    The closest I could find is 4x 125 mm from some Yamaha's
    http://www.myboltpattern.com/atv-bol...bolt-patterns/
    thank you buggy builder, my measurement was about 124 so 125 that should work. and I may just having the wheels drilled from factory if I cant find any. I found in another post that douglas wheels will do that for you for about 10 dollars extra per wheel. thanks again everyone for your input
  1. ATV bolt pattern link
    By Deranged in forum Suspension - Wheels & Tires
    Last Post: 12-18-2012, 04:37 PM
  2. ATV wheels with 5x4.50 bolt pattern? Where?
    By Trouble675 in forum Suspension - Wheels & Tires
    Last Post: 11-27-2012, 06:49 PM
  3. Weird bolt pattern?
    By tekkski in forum Suspension - Wheels & Tires
    Last Post: 11-01-2012, 12:24 PM
  4. 5x115 Bolt Pattern
    By greasemnky in forum Suspension - Wheels & Tires
    Last Post: 03-11-2009, 01:27 PM
  5. Polaris Bolt Pattern
    Last Post: 06-08-2007, 10:12 PM
