Results 1 to 9 of 9
    Front upright & brake combo with s10 hubs
    I have s10 front hubs.
    Building a 2 seat buggy powered by a bike engine.
    Trying to figure out an upright design that will give me front brakes
    I got to this point..The circle plate with the mounting holes for the hub are not dimensiond correctly as I don't have the hub sitting in front of me
    Thanks
    Re: Front upright & brake combo with s10 hubs
    This was supposed to be a picture...apparently it didnt work.
    I don't get why the site does that. Doesn't like to do attachments...
    Guessing its a standard bolt on wheel hub bearing unit? What about pressing out the lug studs, having a rotor made to matching lug pattern, then slipping studs thru rotor and back onto bearing unit. Bearing unit would need to be fairly flat where rotor sets but? Had RickS make me some on old car, think they were 3/16? And used some m/c calipers i had.
    Mar 2012
    Wellington, New Zealand
    Hey Mxer, I have been working on the same thing, trying to use the 2wd front hubs in my upright design. The biggest challenge is how to mount the calipers and mount the bearings. I have started looking at the Nissan hubs, the flange for mounting the bearings is more vertical than the intrepid which is triangular in shape. i will send through a design if I think it will work.
    cheers.
    tbwcurtis - sounds good. Let me know what you find.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    I used hubs/bearings, rotors, and caliper of of the back of a fwd Dodge Caliber. The hub pattern is rectangle with 4 bolts. The wheel bolt pattern is a more common 5x4 1/2. Inexpensive and easy to get parts anywhere.
    Happy New Year!!!!!!!!!!
    I also used S-10 rotors and welded S-10 spindle snouts in.
    Used Willwood calipers on Kartek caliper brackets.
    It worked great and was easy set up.
    You can find rotors and bearings at any local parts store.
    Project X
    Sep 2008
    Allendale MI
    I would go with what Project X said. If you go with the bearing unit from a 4wd, there usually is a splined stub with a nut on it. I believe that holds the bearing unit all together. another option would be a Dana 35 snout.
    Justin
    Nowhere near the desert.
  1. Need advise for front upright joint & bolt size
    By daaboots in forum Suspension - Wheels & Tires
    Last Post: 01-04-2016, 09:26 AM
  2. Replies: 3
    Last Post: 04-10-2015, 03:22 AM
  3. Front upright Examples
    By DieselTwitch in forum Suspension - Wheels & Tires
    Last Post: 01-25-2013, 03:20 PM
  4. Tatum Combo Front Hubs/Discs
    By standfast in forum File Library
    Last Post: 09-04-2008, 09:53 AM
  5. Street wheel/tire combo for 400 ex front hubs.
    By Montanaminirail in forum Suspension - Wheels & Tires
    Last Post: 02-15-2006, 09:11 AM
