Results 1 to 6 of 6
    Front Hub Design
    Mar 2012
    Wellington, New Zealand
    Morning Lads,
    I have found a pair of custom, billet aluminium, front hubs that are supplied with Aluminium calipers and MS disks, these were purpose built by the previous owner. He used the Chev stub axle to set the bearings etc... My question is, do any of you "bright sparks" out there have the dimensions of the front, non-drive stub axle. I would either like to buy a set from a trailer manufacturer or worst case machine them up on a lathe. Any thoughts?
    Secondly, does any one know anything about these calipers?
    Cheers,
    Re: Front Hub Design
    It looks like everybody is drawing a blank on this one. Sorry.
    Clean it up and take it to someplace like Tractor Supply and see if it fits on any of their axle parts. Check the OD of the bearings and see if they're "standard" trailer stuff. May be the easiest way to figure it out.
    Mar 2012
    Thanks guys, good idea about the tractor supply K-Fab.
    Cheers,
    Calipers look like standard 3.5" mount calipers. Should take common pads. You should be able to match them up with Wilwood pads.
    Mar 2012
    Thanks guys, missed out on the hubs. Thanks for all the help!
  1. New Front Hub Design!
    By Linden1234321 in forum Suspension - Wheels & Tires
    Last Post: 03-22-2016, 09:13 PM
  2. front suspension design w/o physical wheels/tires to reference?
    By shane12286 in forum Suspension - Wheels & Tires
    Last Post: 10-07-2015, 07:43 AM
  3. The right track or the wrong track? (front suspension design)
    By shift72 in forum Suspension - Wheels & Tires
    Last Post: 03-14-2013, 12:01 PM
  4. VW front suspension design
    By LarryW in forum Suspension - Wheels & Tires
    Last Post: 06-30-2007, 12:17 AM
  5. Front A-Arm Design
    By diirk in forum Suspension - Wheels & Tires
    Last Post: 01-14-2006, 10:16 AM
