Thread: tire options
Results 1 to 8 of 8
    tire options
    Mar 2015
    Yettem California
    Hello all
    My VW powered buggy I had 32/11.50/15's on the back, way to big for stock 1600 and gearing so I switched back to a 225/75r/15, works out about right they are 27" tall but I would like a little wider without going taller, not easy to find so I started looking at UTV tires and ran across these maxxis ceros radial tire 27/11/15's they have a load capacty of about 1000 lbs . Any reason I couldn't run them on a standard 15" wheel non beadlock? . It would be a lot easier and cheaper than swapping ring and pinion or big bore stroked engine
    Re: tire options
    I run 235/70 Fedima EvoExtremes on my woodsbuggy/safari rail.
    Re: tire options
    Mar 2015
    Yettem California
    That is a nice looking tire, could get interesting drifting with swing axle setup.
    Re: tire options
    Mar 2015
    Yettem California
    Well bit the bullet and ordered a pair so we shall see how well they work. i did call the dealer first about mounting them on a standard 15" wheel and he said it will work fine. I'm just not sure what size and backspace I want to run yet so I will try an old pair of 15/8 with 2" back space and go from there .
    http://www.maxxis.com/catalog/tire-194-111-ceros
    Re: tire options
    Mar 2015
    Yettem California
    I am impressed with the performance of these, they measure about 26" + tall and handle good on swing axle . I like em so much I ordered the fronts 27/9 and a set of the old white star wheels 15/7 fronts and 15/8 rears with 3.5" backspace . Lost a little ground clearance but gained a lot if low end torque
    Re: tire options
    Cool, the ITP ultracross gets good reviews too, the tread is a little tighter than the ceros, but it comes in the same size.
    Re: tire options
    Mar 2015
    Yettem California
    Yep the ITP's look good too, I just went with these because of the diameter and weight capacity. I got the new back rims and center caps installed just waiting on one more rim and the front tires to show up. after I get them installed I will post a picture. I think I may covert this one to IRS, I have the arms.plates,bars,and trans just need to figure out if I want type 2 or 930 cv's , I'm thinking with stock length and width arms the type 2 should be good with the type 1 trans
    Tom
    Re: tire options
    Mar 2015
    Yettem California
    I got side tracked playing with carburetors after I got the tires on , anyway the tires worked out great , with the stock 1 barrel carb it pulled ok in 4th gear and now that I have dual 36 dellorto carbs plus upgrade 009 distributor with electronic ignition it really scoots, took a while to get it dialed in but I can say it was well worth it .
  1. What are my options
    By GoneGonzo in forum Motor - Engine
    Last Post: 02-18-2014, 03:29 PM
  2. Paddle tire options for single seater
    By NinjaRaptor in forum Suspension - Wheels & Tires
    Last Post: 09-18-2013, 08:44 AM
  3. 12" trailer rim tire options ?? ...
    By Xbird in forum Suspension - Wheels & Tires
    Last Post: 07-27-2013, 06:41 PM
  4. 20-30k car - best options
    By freak in forum MiniBuggy.net Lounge!
    Last Post: 05-12-2009, 11:56 AM
  5. motor options??
    By busapower in forum Motor - Engine
    Last Post: 10-03-2006, 06:03 PM
