I thought it was so simple, I was just a little bit WRONG.
Here's how we normally talk about seeing zero bs.
The error? The drawing is xy is parallel to the bulk head/suspension pivot.
But in the total xyz the suspension has 10degs of rake.
Added circles to the spuds and found -0.340 toe change
To fix- rotated the bump and droop spindles (on their kingpin axis) to zero toe and re-plotted my inner tie rod location...
A very note worthy changeBasically the rake/caster/camber/kpi skewed in to BS.
Results 1 to 3 of 3
- Join Date
- Nov 2009
- Location
- Coos Bay, 10 miles from the OREGON DUNES!
- Posts
- 2,154
07-23-2016 02:18 PM
07-25-2016 01:56 PM
That explains why my calculated (no CAD) pivot points where not right when it was mocked up with real parts.
07-25-2016 06:50 PM
I've always figured out bumpsteer in 3D - point the wheel straight at bump, ride height, droop and create points for the steering tab at each of those 3 locations. Create a plane and sketch a circle that uses the 3 steering tab points on the OD of the circle and the center of the circle is where the inner tie rods need to pivot.
A-arm and bump steer.
By T-man in forum Suspension - Wheels & TiresReplies: 24Last Post: 11-17-2015, 07:01 PM -
Bump Steer
By Jan-Willem in forum Suspension - Wheels & TiresReplies: 12Last Post: 04-23-2015, 05:53 PM -
Bump steer cure.
By SCEADU in forum Suspension - Wheels & TiresReplies: 5Last Post: 10-09-2011, 06:18 PM -
Bump Steer Question?
By JaRiv in forum Suspension - Wheels & TiresReplies: 10Last Post: 01-21-2009, 12:05 PM -
Bump Steer
By KWiKSand in forum Suspension - Wheels & TiresReplies: 15Last Post: 09-11-2006, 04:24 PM
