Results 1 to 6 of 6
    Shock orientation - Horizontal
    Mar 2012
    Wellington, New Zealand
    Hey Guys,<br>What are your thoughts on the orientation of the shocks in this buggy. He lies the shocks horizontal and actuates through a braced triangular fabrication. Saves on shock length. How would the adjust-ability and setup for damping etc.. be compromised ?
    https://www.youtube.com/watch?v=hPwf8YDPwkk
    Battling to attach this video!
    Re: Shock orientation - Horizontal
    Saving on shock length can be done in the traditional way by moving the shock mount inward on the arms. You run into problems with tuning the shocks since your low and high shaft speeds are both relatively slow, which makes it hard to get enough dampening without making it stiff on the low side.
    There is also the bellcrank setup race cars use sometimes, which gives extra progression depending on the bellcrank ratio and the motion profile they rotate through.
    Im not sure if either design is worth the extra headache, weight, or complexity. Look at the cars winning the races. Seems like they all use nearly the same setup.
    Apr 2016
    Castellar del Vallès
    it's not only an horizontal shock it's a mono shock, it's not really independent suspension because one wheel movement will affect the other.
    IMMO i would do a traditional shock position.
    Nah, it is not a mono shock. The other shock is hiding directly behind. You can see where the shock mounts to the frame.
    Mar 2012
    Thanks Guys, what is the best location for a shock. i.e. how far out towards the hub from the inner mounts? 3/4 of the arm length?
    Cheers
    Apr 2015
    UK
    Depends entire on how much travel you have on your shock, arm, etc, etc.
    Rule of thumb - as far out as possible.
  1. Radiator orientation
    By Joe in forum Cooling
    Last Post: 02-17-2013, 09:41 AM
  2. Radiator Orientation
    By uzrnaim in forum Cooling
    Last Post: 05-24-2011, 10:43 AM
  3. Engine Angle How Close to horizontal??
    By Martinm210 in forum Motor - Engine
    Last Post: 03-08-2010, 03:53 PM
  4. Horizontal/Vertical band saw
    By moneypit in forum Shop Talk
    Last Post: 09-08-2007, 08:14 PM
  5. Horizontal digital protractor?
    By Mike in forum MiniBuggy.net Lounge!
    Last Post: 12-02-2006, 07:18 AM
