Results 1 to 7 of 7
    Shock orientation - Horizontal
    Mar 2012
    Wellington, New Zealand
    Hey Guys,<br>What are your thoughts on the orientation of the shocks in this buggy. He lies the shocks horizontal and actuates through a braced triangular fabrication. Saves on shock length. How would the adjust-ability and setup for damping etc.. be compromised ?
    Re: Shock orientation - Horizontal
    Mar 2016
    Ionia, Michigan
    That's called cantilevering, adn it's been in use in race car's for awhile. My Traxxas Revo also uses the method, it's really effect at getting more wheel movement out of a shorter shock since you can have a ration like 2:1 or whatever built into the lever. It saves alot of space as well.
    That's not a true bellcrank setup. What he has there can be done with the shocks directly to the arm in a vertical fashion.
    Mar 2016
    Ionia, Michigan
    Quote Originally Posted by plkracer View Post
    i had to go back and look, you're correct, that's just a weird upper arm hooked to the shock. Haven't seen that before.
    Yeah, that provides no benefit, besides looking different, and maybe protecting the shock from rocks.
    Apr 2015
    UK
    Common setup from 60's f1 cars to get the shock into the body out of the wind. Suppose he may have done it to:
    a) Get them away from any damage
    b) Look cool.
    I'm going B.
    Jan 2009
    Los Angeles
    Very minimal travel, too many weak links.
  1. Radiator orientation
    By Joe in forum Cooling
    Last Post: 02-17-2013, 09:41 AM
  2. Radiator Orientation
    By uzrnaim in forum Cooling
    Last Post: 05-24-2011, 10:43 AM
  3. Engine Angle How Close to horizontal??
    By Martinm210 in forum Motor - Engine
    Last Post: 03-08-2010, 03:53 PM
  4. Horizontal/Vertical band saw
    By moneypit in forum Shop Talk
    Last Post: 09-08-2007, 08:14 PM
  5. Horizontal digital protractor?
    By Mike in forum MiniBuggy.net Lounge!
    Last Post: 12-02-2006, 07:18 AM
