Results 1 to 4 of 4
    Changing wheel offset
    Hi everyone.
    I have only posted once on this board but I do troll this site. I have 3 Honda F350 oddy's.
    One has been totalled due to a bad crash.
    Like you guys here I like to fab my own parts and pieces.
    Somewhere on this site (I believe) is a post where someone here has changed the rim offset by removing the inner hub and flipping it around. I can not find this post. Can someone direct me to this post by posting a short cut to it ??
    Hope I can find this post again LOL.
    Thanks in advance for any replies.
    Re: Changing wheel offset
    Jun 2015
    Texas Panhandle
    What's you're goal? I don't know what you mean by flipping the hubs around, but maybe if I understand what you want the end result to be I can help you along.
    Jan 2009
    Los Angeles
    You cant flip the hub because most hubs use 2 different sized bearings, so the outer bearing wont fit on the spindle if you flip the hub. Also the brake rotor wont line up with the caliper.
    You can flip the wheel if the outside of the wheel is flat to seat against the hub. This wheel change your wheel offset either further out or closer in. But by doing so in the front, it changes your steering geometry, KPI, Scrub Radius. This change will affect what you feel on the steering wheel.
    Post some pics of what you have.
    Senior Member lillert's Avatar
    Jan 2012
    Norway
    On steel rims you can cut out the center piece and flip it. It's usually welded in 4 spots. Like this:
  1. Changing Seal in RPM box?
    By rgvkid in forum Driveline
    Last Post: 08-05-2013, 04:15 PM
  2. changing motorsports
    By rattlesnake95 in forum The Welcome Mat
    Last Post: 03-13-2010, 03:03 PM
  3. Wheel offset diffrence?
    By scdlguy in forum Suspension - Wheels & Tires
    Last Post: 02-04-2009, 07:37 AM
  4. Changing jets in a two smoke
    By butch in forum Motor - Engine
    Last Post: 04-22-2008, 12:24 AM
  5. changing snout position
    By Boyd in forum Suspension - Wheels & Tires
    Last Post: 09-29-2006, 04:39 PM
