Results 1 to 4 of 4
    Brake master cylinder size
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    I have this 5/8" diameter master cylinder. I want to use it with 2 front brakes from an ATV, and one rear willwood caliper I got from protodie. Do you guys figure 5/8" master cyl will be large enough for 3 calipers? Maybe need to upgrade to 3/4"?
    Re: Brake master cylinder size
    Mar 2009
    Ontario , Canada
    You should be fine with what you have. Most ATVs would have a 10 or 12 mm Master. Which model of Wilwood caliper do you have?
    Dec 2013
    Ontario Canada
    Its this one, its a single piston caliper.
    brake caliper
    BTW Harv, what part of Ont are you at?
    May 2013
    Easton, PA
    13mm is the atv/bike standard bore, I upped to a 5/8ths bore to run 2 calipers. a large part of the choice has to do with how much piston travel and fluid displacement there is in the calipers. Try the 5/8ths, but you may need to upgrade because of the difference in the calipers
  1. master cylinder size
    By gvouvakos in forum Controls and electrical
    Last Post: 09-08-2012, 06:51 AM
  2. brake master cylinder
    Last Post: 12-17-2011, 01:47 AM
  3. Brake Master Cylinder
    By Glamisman in forum Controls and electrical
    Last Post: 10-02-2011, 07:45 PM
  4. Brake Master Size
    By greasemnky in forum Controls and electrical
    Last Post: 03-22-2009, 09:23 AM
  5. Brake master cylinder ?'s
    By lyinlow in forum Controls and electrical
    Last Post: 01-29-2007, 05:10 AM
