Results 1 to 6 of 6
    How to take apart stock ody 250 shocks
    Jan 2014
    5 Min from the dunes!
    Hi guys,
    As the title says I cannot figure out how to take apart these front shocks on my ody 250 for repaint and love. I have looked at the owners manual and it seems as you crunch the spring down so then you unscrew the two half's So I got a ratchet strap and scrunched the spring down. I couldn't get it to screw apart so now i'm stuck... Any help or suggestions? I may try it with a ratchet strap on both sides to get even compression and that might make it so it slides out, but idk yet.
    Thanks.
    -Fl350 resto mod-
    -Wind turbine electrician-
    Re: How to take apart stock ody 250 shocks
    Pix please.
    Did you get the springs off? That has to be done first (obviously).
    Jan 2014
    Pix please.
    The photo out of the owners manual
    Getting the spring off is what I am having troubles with.
    -Fl350 resto mod-
    looks like you have to compress the spring enough to get an open end wrench on the locknut that's under the top eye. then slip a metal rod or screwdriver through the eye and use that and the wrench to unthread the eye, then the locknut. Only puzzling thing is the "pull out" with an arrow--i think that refers to making sure the eye and locknut are clear of the hole in the top plate of the compressor.
    Agreed with Xbird.
    I didn't realize that's what you were trying to take apart. Sorry about that.
    If you don't have a spring compressor, you should be able to go get one at the local auto parts shop - they loan them out. It won't be like the one in the pic, it will be a pair of clamps that fit on each side of the shock and pinch the spring.
    Heat would probably help too, as I'll bet they're stuck on really well. But you don't want to burn the bushing in the end of the shock. You're in for a fight, unfortunately - or should I say likely?
    Jan 2014
    Hey thanks guys, I had trouble understanding the diagram about the location of the lock nut but I got it now. Good idea K-fab I am going to try the ratchet strap technique and hopefully don't break anything I will have to try the auto stores if it doesn't work. School and work is getting in the way of the project but I hope to get pictures of whatever happens tomorrow.
    Thanks.
    -Fl350 resto mod-
  2. FL350 stock vs aftermarket upgrades
    By NukeEm1 in forum Honda's Pilot & Odyssey
    Last Post: 04-02-2014, 07:01 AM
  3. Formula Desert Lites
    Last Post: 07-22-2013, 09:22 PM
  4. Air Shocks
    By ringgo1star in forum Projects in Progress
    Last Post: 11-10-2012, 06:49 AM
  5. Shocks
    By r97 in forum Suspension - Wheels & Tires
    Last Post: 07-05-2012, 11:20 AM
