Results 11 to 20 of 34
    Re: How to design and build A-Arm suspension
    Laguna Niguel, Commifornia
    Deaner: there was a typo in step 8. I corrected it to say lower a-arm "outer" pivot. All you are doing with this step is making your lower arm Arc.
    Sorry I haven't followed up my post this week. I've been super busy with work.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Flyerrider, thanks for the clarification. I still don't get how you take roll center into consideration.
    I'm trying to redesign the front suspension on my barracuda because its not god enough for the racing I'm trying to do. Just a quick couple of questions .
    1. Where do I want my roll centre to be? What is considered good and what is considered bad?
    2. Akerman on no Akerman? Is the intersection of the front spindle arm and KPI at the same angle as the upswept nose or parallel to the chassis if that makes sense?
    My understanding is for steering arms mounted n the front of the spindle, you project a track length line in front of the buggy and this is where the lines that go through the KPI and the steering arm should intersect?
    Thanks.
    Deaner ,read the post that I posted (allow myself to introduce...myself) by Damien,he mentions a common approach to roll center.
    Bend-Tech Dragon Master
    Nov 2009
    Quote Originally Posted by Iggsy View Post
    Unless its an all out dez car, you'll need some Ackerman ...
    For steering rods I draw 3 spindles, one bump-one ride height-one droop.
    Make sure you copy the tie rod locations.
    Then veiwing plane parallel to the suspension draw a 3 point arc thru the centers of the spindle steer heim joints. The center of this circle will be your tie rod location.
    Nov 2009
    'cept thats for a rear steer
    Nov 2009
    Yeah that was for a guy doing a Pilot.
    Sep 2011
    Northern Ohio
    Thanks, I read it but he doesn't say much about roll center. I'm going to read it again.
  1. Replies: 110
  2. Suspension Design
    By yldvlt in forum Suspension - Wheels & Tires
    Last Post: 08-17-2012, 04:19 PM
  3. Suspension design?
    By GearHead101 in forum Suspension - Wheels & Tires
    Last Post: 11-22-2011, 01:30 PM
  4. Side x side design and build.
    By Mike in forum Projects in Progress
    Last Post: 10-23-2007, 01:10 AM
  5. We need another good suspension design thread.
    Last Post: 08-13-2007, 10:15 AM
