Results 1 to 10 of 12
    Recommendations for CV's????
    Exclamation
    I have stock vw cv's that I used for mock up. They need to be replaced and right now I am cycling just under 12 inches of travel, I was wondering what you guys recommend for new ones and where to get them cheap. Which would be good to get more travel?
    Thanks for your help!!!
    Re: Recommendations for CV's????
    Senior Member Gotted's Avatar
    Apr 2008
    Clarkston WA.
    Take a look at Dan's
    Buggy Transaxle - Page 1
    "Imagination is more important than knowledge"
    What size cv's. The typw 2 offroad ones fron Dan are a good deal. What type rear suspension.
    If your flanges are already type 2, I think type 4 are the only ones that will mount up and provide more travel.
    I believe they are type 1, I am not positive though.
    Pic of rear drive, I couldn't find one of your setup. Measure the cv's and post up.
    Exclamation
    okay I will measure it tomorrow but here is a picture
    Everything that could be done wrong on those arms has been done. Are they just for mock up?
    No they are not for mock up. Why what is wrong with them? They cycle perfectly with no binding anywhere.
    Cv's will prob be fine. What MC is calling a possible failure, are the trailing arms. You may not be done, but post up some pics from side straight in and from rear. Some additional bracing is need. On frame too, where outside arm is mounted. What is the wheel hub from?
  1. Ackerman angle recommendations
    By tbwcurtis in forum Controls and electrical
    Last Post: 03-25-2012, 01:41 AM
  2. Need some exhaust work in Vegas? Any recommendations?
    By scott534 in forum Motor - Engine
    Last Post: 10-08-2010, 09:43 PM
  3. Fire extinguisher recommendations
    By Stoneman in forum MiniBuggy.net Lounge!
    Last Post: 08-01-2010, 11:24 AM
  4. sachs 300cc cvt driveline recommendations
    By s_c_engineering in forum Driveline
    Last Post: 12-20-2009, 11:00 PM
  5. SXS Shock Recommendations
    By kylewest1320 in forum Suspension - Wheels & Tires
    Last Post: 02-14-2008, 01:41 PM
