Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
    Shock Pictures, please give feedback, good, bad, horrible, placement?..?
    Jun 2011
    Muskegon Michigan, Beertent Capital of The World!
    Exclamation
    i am a new buggy builder. any tips comments or any info at all will be helpful. thanks guys.
    -Mike
    Re: Shock Pictures, please give feedback, good, bad, horrible, placement?..?
    Oct 2008
    Lakeport CA
    Be prepared for a million ideas....lol
    An easy question is did you remove the spring from a shock and cycle the suspension to make sure that frame on ground is your bump-stop?
    Petoskey, Michigan
    Question to Evan. Why would a person use the frame as a bumpstop on the ground? Not a good idea IMO.
    That said it looks like the shocks will be doing some twisting that is not desired. Also with that front steering link as you see it from the side. How bad is the bump steer?
    I am also not crazy about the top shock mount. I know it gets done like that a lot but I still do not like it. Just a me thing maybe. But its hard on the tube to have that sticking out on that perch.
    Also no king pin inclination on the spindles. ??
    Petoskey, Michigan
    Also you will want the top arms shorter. Make them shorter and give it some KPI at the smae time. You will be GLAD you did.
    Jun 2011
    ok, i have no idea how to answer any of these questions.. help....
    Jun 2011
    can u give me a rough size difference from top to bottom? i can fab anything. just the knowledge behind the fabing is the part that im not always great at.
    Jun 2011
    the steering tab i tacked for the moment. once tires are installed i will relocate to achieve ackermin.. right? align the tabs to the center point of the rear end?
    Jun 2011
    was this wrong to do?
    when installing the front shocks. i welded mounting tabs on the bottom A-Arm first. after this i set a Angle Measure on the a arm and raised 2*. set the top mounts at this point. repeated on the other side. both sides are at the same angles. i figured this so i wouldnt max out/ over extend or damage ball joints? should i have done this at MAX travel and mounted at max traveL?
    Petoskey, Michigan
    I aint trying to be mean here just blunt to the point. Most of us have done just what you are. So eager to build we build then find out we did things that will make the buggy ill handling. I know I have!
    Anyways I would also ask. Is the frame level in the pic you took from the side? It looks like the spindle is leaning forward (the top is in front of the bottom). If it is the buggy will handle VERY poorly at ANY real forward speed! (say over 10 mph!)
    What of these words do you know. Really know and understand. So good you can explain them!
    Camber
    Caster
    Ackerman
    KPI (King Pin Inclination)(Also called ball joint angle)
    Scrub
    Scrub radius (very different from scrub)
    Bump Steer
    There are a lot more but lets start with these.
    Jun 2011
    Im a front end virgin. I have the most basic of definition for all of those words... also the spindle is 90* to the tube that connects the top n bottom a arm... if their are any pictures or measures u need I can take them and post for u to possibly help me better.
  1. mounting shocks
    By jerry in forum Suspension - Wheels & Tires
    Last Post: 06-05-2014, 04:36 PM
  2. Shock length, is longer better?
    By dunerocket in forum Suspension - Wheels & Tires
    Last Post: 12-12-2009, 01:43 PM
  3. We need another good suspension design thread.
    Last Post: 08-13-2007, 10:15 AM
  4. Shock placement in relation to Suspension movement
    Last Post: 11-20-2006, 11:24 AM
