Results 1 to 4 of 4
    What size air shocks do you think I should run.....
    Question
    Thanks for the advice....
    Re: What size air shocks do you think I should run.....
    The geometry on this thing is all wrong for how you plan to use the car. Camber change is insanely wrong and is going to cause no end of problems IMO.
    This is ripe for new A-arms and spindles. Wouldn't be that difficult to do now since you will eventually do it anyway after it comes unglued.
    Have you checked out this suspension calculator to see what it would take to correct the problem? Just measure your frame pivot mounts vertically and enter that into the calculator. Then change the spindle hieght and hiem location to get negative camber from full droop to full bump.
    http://www.racingaspirations.com/?p=286
    Do this before thinking about shocks - IMO.
    Ok thanks
    And look up a recent post by Damien in response to front A-arm design. You need to read it!
  1. Revolution Racing Shocks - New bypass shocks
    Last Post: 08-04-2016, 01:03 PM
  2. Shocks Questions!
    By elvergonmexicano in forum Suspension - Wheels & Tires
    Last Post: 01-18-2007, 06:18 PM
