Results 1 to 9 of 9
    Steering angle for turning
    Senior Member TEO's Avatar
    Jun 2009
    Syracuse, New York
    Is 30 degrees in each direction on the uprights enough travel in a spherical bearing with mis-alinement bushings for steering a small single seat buggy?
    TEO
    Re: Steering angle for turning
    Petoskey, Michigan
    Others will pipe in but wheel base will make a big differance so for others sake telling the length of the wheelbase if you know it will help.
    Jun 2009
    Syracuse, New York
    Sorry, We're looking at approx. 88" wheel base with a track of 48".
    TEO
    Jun 2009
    Syracuse, New York
    I also see that the 60 degrees included is about max angle on most rod ends.
    TEO
    Jan 2007
    Metamora, Michigan
    Are you sure that's your correct wheel base?
    That seems super long for a car that only has a 48" track width.
    If you plan to run Ackerman you'll need to turn the outer wheel around 25.5* and the inner approx. 32.5* (with that wheel base) This would only leave 1* at either end of your steering before you max out the joints in the HMS.
    Also, where your a arms attach to the spindle uprights the rod ends would need to angle back around 5 or 6* in order to get the max out of the joints.
    Even if you run Ackerman 58 total degrees is plenty, but the trick is designing it to utilize the full 58 without maxing out the joint.
    Jun 2009
    Syracuse, New York
    After further checking the width is more like 58" (depending on wheel offset). Is the wheel base to long?? in terms of a smaller machine. How do you figure out turn radius? I thought the inside wheel on a turn would be more than 30 degrees from straight. Any explination would be appriciated. Thanx.
    TEO
    that should be plenty of steering angle.
    I calculate you'll have a 13' turning radius if you put in Ackermann.
    It would be 11 if measured to the rear wheel instead of the front. That is based on the inside tire being at 33.5 degrees and the outside at 26, distance between steering pivots, 48", 88" wheel base.
    45 on the inside and 33 on the outside gives 7.3'.
  1. help with steering
    By u2slow in forum Suspension - Wheels & Tires
    Last Post: 10-09-2009, 10:27 PM
  2. Quick steering question, ATV spindles
    By andy777bmx in forum Controls and electrical
    Last Post: 10-07-2009, 08:41 PM
  3. Will this steering work? (Bump steering?)
    By RD350LC in forum Controls and electrical
    Last Post: 06-14-2009, 06:26 PM
  4. My First Buggy Build
    By Jabo in forum Projects in Progress
    Last Post: 06-07-2008, 04:44 AM
  5. home made build
    By 50nuts in forum Projects in Progress
    Last Post: 03-25-2008, 05:31 PM
