Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
    Re: ST4 Hayabusa Build
    K-fab. Haha hell ya! Arizona would be awesome. Ill need some one to show me around out there though. I bet there are a lot of hidden gems all over there.
    Build looks great!! Is there any concern with flex on the upper A-Arm mounts? I do not see where they are tied into the main chassis to reduce flex under load or heavy cornering.
    CWI CWS CWE
    was kind of wondering that myself......is that what the st4 plans spec out?
    The A-arms mount are denominational to spec of the plans. However the material is called for was only .188 A36...I ended up using .25 4130 and adding extra gussets on the inside. = It definitely did the trick on making it solid, but next time i will change it up and go straight to the chassis...just easier that way.
    .25 wall for the arms? Holy crap! The .188 would more than suffice.
    You’ll never have issues bending one... But if you do have a crash you’re gonna end up tearing up the frame instead of the arm.
    It’s better to build suspension components (or their mounting points) to be the sacrificial item.
    The arm mounts are .250... not the arms :-). If you look at the upper A-Arm mounts, I was asking if they might incur flex since they weren't mounted to the chassis and just looked to be 2 sets of "ears" supporting the upper arms.
    CWI CWS CWE
    Ah, I misunderstood.
    Nevermind.
    Here are 2 videos of it in action. Noting too crazy but fun little videos.
    https://www.instagram.com/p/Bt96J3gl..._web_copy_link
    https://www.facebook.com/jason.slayt...209450438/?t=1
  1. Hayabusa turbo engine high end build
    By Dustinp in forum Craigslist, E-Bay and Internet listings
    Last Post: 01-25-2016, 05:42 PM
  2. Gen 2 Hayabusa
    By JD66 in forum File Library
    Last Post: 11-11-2015, 04:48 PM
  3. Hayabusa GEM Car
    By trlkidd in forum Show off your toys in here!
    Last Post: 11-05-2012, 11:23 PM
  4. Ky 2 Seat Hayabusa Minilite Build For Utv Rally Raid Racing
    By Xtreme Fabrication LLC in forum Projects in Progress
    Last Post: 09-05-2012, 05:58 PM
  5. Sand Bullet Hayabusa 2-Seater build -- need help
    By BuggyManiac in forum Projects in Progress
    Last Post: 09-20-2010, 11:37 PM
