Page 3 of 28 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 272
    #21
    Little more progress
    #22
    Haven't had much time but got a few more tubes in there, i want to mount the engine so i can pull it out and move the frame on the table so I'm at a bit of a hold up
    #23
    Nice!
    I like the rally car style cage!
    Looks strong.
    #24
    I suck at taking pictures while I'm working, got a few last night to show progress. I got motor mounts made, the engine and trans hold themselves in, that allowed me to tack in the rear suspension mounts. Pulled the drivetrain out and started on the front it is all tacked up waiting on more tubes.
    #25
    You are moving right along!!!
    #26
    Got to work on the front end last night but my Chinese hole saw notcher finally gave up
    #27
    Oct 2009
    Truckin in high gear ae Looks great!!!!
    #28
    Pretty clever idea on the motor/trans mounts. Are you going to run some sort of donut for isolation, or just hard mount them?
    #29
    I use an energy suspension donut type mount https://www.summitracing.com/parts/ens-9-4101g one half goes between them and another on top to give it some give. They are firm poly so it should be enough movement to avoid breaking cases but firm enough not to actually move around. the stud makes engine removal and install easy too
    #30
    Started welding this thing up, all suspension is still just tacked incase it needs tweaked, still a few tubes left but I needed a break and some parts
  1. Another VW Powered buggy
  3. Diesel powered buggy
  4. New to mc powered buggy
  5. cb750 powered buggy
