Page 13 of 13 FirstFirst ... 3 11 12 13
Results 121 to 127 of 127
    Im really blowing it with updates, but the buggy is on all 4s holding it's own weight, i did make a spreader for the steering but i don't have pics. Im working on the steering and pedals now
    Good to hear it’s standing on its own.
    Progress looks good..
    Hi, I've been lurking around here gathering ideas to see what parts I can find locally in Peru for an ST4 project. Everyone seems to use the Fox air shock, but they are so expensive, and getting the high psi nitrogen here is difficult.
    I'm curious what coil overs you are using and what the overall travel is? Thanks
    The coilovers I have are 2015 RZR 1000 walker evans off a highlifter if that matters. I cant remember travel I think front is 8 inch rear is like 12 or 14 I think
    As usual i haven't been updating anything, I'm in a mad dash to get it driving in august, pedals are mounted, shifter is mounted in an incorporated center console, all 8 control arms are welded, all steering components are welded, exhaust is welded, radiator and cooling system is welded, im pretty sure anything that can unbolt from the frame is removed and finish welded. Im determining if it is worth having the arms powdercoated and if so what color
    [IMG]https://uploads.tapatalk-cdn.com/20190719/325684316178fd058b39979be7f464d5.jpg[/IMG
    Looking good!
    Those are inappropriate shop shoes. No visible toes?
    I’m not looking forward to that finish welding stuff... got at least a week’s worth.
    Put it back together and run it a bit before powder. Never fails that as soon as you add color you end up needing to weld on it because of some unseen thing.
    As of right now i was only going to do the control arms and uprights, as i can't imagine what would need changed on them. And for the hassle of cleaning them (the only parts that rusted) and just painting then it's worth the 200 i was quoted plus i wont have to allign it twice haha. I do plan to just rattle can the frame to keep rust away for a while though
  1. Another VW Powered buggy
  3. Diesel powered buggy
  4. New to mc powered buggy
  5. cb750 powered buggy
