Page 12 of 28 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Results 111 to 120 of 272
    I got my suspension today, its just rzr 1000 stuff. My question is when setting up my shock mounts to bottom out the shock at full bump which is about 4 inches of the ground. The shocks have a hard foam bumpstop on the shaft, do i consider bottomed out having the foam fully compressed or just when it starts to make contact?
    I want to make sure i get this pretty right and can set up for the wheel travel i need
    Those bumpers are pretty hard. I’d guess maybe 1/2 squish during one of those kidney killer bottomings.
    Set up sitting on the bumper - the minimal excess won’t make a difference.
    ok ill shoot for half squish at 4"
    Other projects have been keeping me from the buggy, I fell into to good of a deal to body swap my tube frame ranger which is almost done, (pics below just because).
    I did take a minute to work on the buggy yesterday and I have a question, for my rear lower coilover mount, it lands right on the control arm tube (almost like i meant for it to happen) but the tube is at about a 45 degree angle from the chassis, will i run into any issue with the mount not being perpendicular like you'd prefer? I could build a little platform off the tube but it seems simpler to just weld 2 tabs to the tube and be done. looking for ideas or examples, red dot in the picture is where the mount will be
    You’re looking to get the shock as perpendicular to the arm as possible at full compression. You should be just fine mounting where you’ve shown.
    but should i be concerned about the angle of the tube? I feel like ill have bind as the suspension cycles. I might go ahead and make a little platform on the arm for the lower mount so there is no missalignment
    I wound up making a piece to ad to the control arm for the lower mount, i also added the last tubes i can think of to the rear of the frame
    I got my rack mounted, did some welding and started mounting my intercooler this weekend, hopefully I can keep progress coming. I have a steering question, I'm using the generic center load rack, will I run into issues just mounting my heims directly to it with no spreader? I know it will affect my geometry a little but will be enough to matter?
    Blog Entries
    1
    Without the spreader bar you will have very bad bumpsteer.
    That's what I figured, I'll be figuring out a spreader this weekend, space is not on my side up there.
  1. Another VW Powered buggy
  3. Diesel powered buggy
  4. New to mc powered buggy
  5. cb750 powered buggy
