Results 1 to 10 of 13
    My ST4 ish build
    Jan 2016
    Ohio, which is a long way from the desert
    I've wanted to build a mini buggy for years and finally started to get serious. I scoured the internet looking for ideas and finally came across the ST4. I really liked the layout and looks of it, so it was settled...that's what I am going to build.
    In late February I started laying out the frame. I had a large supply of 1-1/2" and 1" .120 wall DOM tube so that is what I used. Sure its a little heavier than I need, but I don't have any strength concerns. I strayed from the plans since I am a bigger guy and need to be able to get in and out of this thing. I made the cabin 8" longer, 6" wider and 6" taller.
    I was able to score an 03 CBR600RR engine really cheap so that became the power plant. Sure I'd love to put a 1000cc or better in it, but I couldn't pass it up.
    Re: My ST4 ish build
    Jan 2016
    More pics
    I decided to use the hubs, axles and wheels from a Cavalier since they are so cheap and readily available.
    Since I am from the automotive world and I have a lot of automotive parts I decided to use a car fuel pump and regulator. I also went with an 8 gallon fuel cell.
    Jan 2016
    I was also able to score the instrument cluster from the CBR.
    Jan 2016
    I was able to take it on its first trip around the neighborhood last night and so far I like it. I need to re-gear this thing with these small tires though. During my research I decided to go with an 11/60 sprocket combo...way too much.
    A few more things and I can blow it all back apart, finish welding it and throw some paint on it.
    This is what it looks like as of now.
    Attachment 35146
    Attachment 35147
    Attachment 35148
    Jan 2016
    A couple more
    Oct 2009
    Lookin great and lots of pictures even better thanx for posting them .....
    Jan 2016
    Thanks,
    It looks like a few didn't come through...
    Hey man, I really like your a-arms with the round tubing. Did you do any drawings for those? I just built my as in the drawing package with the rectangular tubing, but I want to redu them with round. Would you mind sending me some closer up pics or drawings if any of those?
    thanks!
    Jan 2016
    I didn't do any drawings of them unfortunately. They are basically to the same dimensions as the rectangular style I just tweaked them to use an off the shelf bushing. The bushing ends are 1-1/2" .120 wall DOM while the main bar is 1" .120 wall DOM. I just used a short section of tube along with a threaded tube end for the heim joint end. I will try to get you some better pics.
