Results 1 to 5 of 5
    ST4 Master cylinders, size
    Hi Guys,
    I'm wondering if the Master cylinder specified in the plans will be correctly sized for the specified brake and clutch setup.
    I've read a few posts reg. other buggy models, f.ex. SS1000 and the R16, that the guys use a 0,75" master cylinder for the front wheels, but a smaller for the single rear caliper, and even smaller for the clutch (to give enough travel on the clutch-pedal.
    However, for the ST4, the plans specify 0,75" masters for both front, rear and clutch.
    Do anyone have any inpuit on this, and some pointers as to the sizes they are using?
    Thanks!
    /Mikkel
    Re: ST4 Master cylinders, size
    Due to some glitch (or me pressing "submit" more than once), the thread has been posted twice.
    S.W. Michigan
    I run one 3/4 to two front brakes
    one 3/4 to a single rear brake
    3/4 can be used on the clutch too, but I run a 7/8 for a shorter stroke
    5/8 I run when using a single MC to a single brake on the rear with no front brakes
    in that application the softer feel and longer stroke work better
    so the bigger the MC the shorter the stroke and the harder the pedal
    Great info, Protodie!
    Seems the MC's might be correctly sized after all - I guess It boild Down to personal preferences; if one likes a short-stroke clutch, or prefer some travel on the arm for softer shifting.
    I'll have to try for myself when testdriving the buggy.
    Thanks for input (and parts BTW - they cleared customs yesterday, and was delivered this morning to my address in Denmark)
    I run 3/4" masters front and rear , into 4 spot M/C calipers , 2 discs up front and 2 at the rear , with 300mm dia discs all round , The pedal ratio is 6.25:1 This combo makes for a light pedal and run a brake bias bar to adjust braking forces from front to rear
    As for the clutch I run a 5/8" master cyl and I restrict the pedal travel to around 2/3's too much travel here can mess up the clutch , clutch plates can drop , damage clutch springs, crack clutch housings ...... etc etc
    Every buggy is different though
  1. brake master size- master for each wheel.
    By Wheels in forum Controls and electrical
    Last Post: 08-30-2015, 10:49 PM
  2. Wilwood calipers and master cylinders
    By BajaInspired in forum The Drawing Room
    Last Post: 02-09-2014, 08:42 AM
  3. Wilwood master size ???
    By Snoopy in forum Controls and electrical
    Last Post: 07-22-2013, 09:19 AM
  4. Replies: 3
    Last Post: 01-28-2013, 05:46 PM
  5. Leaking Master Cylinders
    By MongooseGSXR750 in forum Controls and electrical
    Last Post: 11-21-2011, 12:42 AM
