Results 1 to 6 of 6
    Largest rear sprocket for ST4
    Jan 2016
    Ohio, which is a long way from the desert
    I am going to be running a 600RR engine in my ST4 and I want to get the best mechanical advantage available. I have already bought an 11t front sprocket, but now I am looking at the rear. I have found some conflicting info as to the largest you can go. I will be running a 520 chain and the sprocket hub design is wide open, but I am curious on how big you can go without extensively modifying the rear cradle. I don't want to keep buying and returning sprockets if I can avoid it. Also where is a good source for these larger sprockets?
    Thanks!
    Re: Largest rear sprocket for ST4
    How much room ya got? I'd shoot for a 60t which is right at 12" diameter, and bump the front to a 12t for a 5:1 ratio.
    Jan 2016
    Who sells a good one?
    I have a 55 tooth on mine and I can't go any bigger because my diff cradle has to slide for chain tension. I'd imagine if you stuck to the plans a 60 tooth would be the absolute biggest, but you may even be needing to grind away the suspension cross bars some for it to work.
    SuperSprox is the way to go. They're tough, have minimal wear and they'll make custom sprockets if needed too.
    Jan 2016
    Awesome! Thanks!
  1. rear Sprocket
    By pauldavies123 in forum Projects in Progress
    Last Post: 06-05-2012, 05:04 AM
  2. Largest Suspension travel ever?
    By nicolasdriver in forum MiniBuggy.net Lounge!
    Last Post: 01-26-2012, 04:40 PM
  3. Rear sprocket ?
    By RDRacing647 in forum Driveline
    Last Post: 11-01-2011, 02:17 AM
  4. rear sprocket
    By NFG in forum Driveline
    Last Post: 04-06-2010, 02:44 PM
  5. rear sprocket
    By jimg2521 in forum Driveline
    Last Post: 10-17-2006, 10:48 PM
