Thread: My ST4 build
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
    Re: My ST4 build
    San Diego
    Ok thanks for the Protodie idea... I am not anywhere near the rear of the buggy yet. I will probobly buy the whole rear setup and not have to deal with it. What I ended up doing for the time being is exactly what you said. A number of tack welds to "hold" it in position. I then re-dialed it and where the mount needed to be moved I took a dull cold chisle and smacked that weld to re-align. It is down to .005. I am going to make braces to prevent movement. I will bolt it to the rotor and tack it to the hub then weld under the brace. If it works great, if not, I will try something else.
    Re: My ST4 build
    Just wanted to upload a few picks of my latest progress. Exhaust is all done. Took two OEM headers and cut them up to fabricate what I needed. Let me know what you think.
    Re: My ST4 build
    Slick!! Exhaust looks close to fnr, wrap it or a heat shield to keep from cooking the grease and bearing.
    Re: My ST4 build
    Ya good call.
    I am thinking of getting it ceramic coated, since I think that looks better than wrap, and wont have to worry about the wrap getting wet and muddy...
    Re: My ST4 build
    Quick update on the project, just got all parts back from powder coat and starting to reassemble everything.
    Re: My ST4 build
    Wow, looking good, wish mine would look at least 1/2 that good
    Re: My ST4 build
    Senior Member iflytii's Avatar
    Jan 2013
    OKC, OK
    Like the tubular a-arms. Red looks really good!
    Re: My ST4 build
    Sep 2008
    Allendale MI
    I have always liked the looks of the ST-4, and you did a fine job on your build!
    Justin
    Nowhere near the desert.
    By leok in forum Barracuda
  3. Kids Kart Build
    By Nobody077 in forum Frame
