Results 1 to 10 of 33
    Almost ST4 with Volvo engine
    Hello, I decided to show my project. I call it almost ST4. Because lengthened and widened front, more legroom. Reinforced frame. And I use a car engine Volvo B4194T. Later I'll tell you more: D
    [/IMG]
    Re: Almost ST4 with Volvo engine
    Do not allow to upload images. How to do it correctly?
    Thank you for your help, now everything will be easier. Glad to join the MBN
    I started to produce the front suspension, but already I see mistakes.
    frame look very smooth
    As I can see Lithuanians taking over MBN forum
    A little update. Rear swing arms is temporary, it will be reworked. And the front fork segment.The width of the appearance of almost 2000mm.Now there is a problem with axle, thinking to leave the original cv joint, but need to lengthen the original axle. But I think the lengthening original axle seem unreliable.Maybe offer how to solve this problem? The engine with small improvements will have about 320-350NM and 170-180KW
    Quote Originally Posted by Binze View Post
    You're going to have to outdo the Aussies - they're joining daily.
    Quote Originally Posted by Renatas View Post
    If the axle is a common spline, you might be able to find some in the US, unless that makes them too expensive.
    There have been some good threads on how to lengthen axles, so try searching in the drive train section of the site.
    a little update
  2. Adding a oil cooler to Arctic Cat 660 turbo engine
    Last Post: 09-14-2013, 07:13 PM
  3. Honda Pilot FL500T Evil Twin build
    By asaszn in forum Honda's Pilot & Odyssey
    Last Post: 04-12-2012, 11:43 AM
  4. Tom's Buggy Build
    Last Post: 08-06-2011, 03:40 PM
  5. Why is Oil So Critical to My Engine?
    By installers in forum Cooling
    Last Post: 03-06-2011, 10:04 AM
