Thread: engine size
Results 1 to 8 of 8
    engine size
    Would a 750 bike engine be enough for an st3? I'm starting to plan ahead before i begin building anything. I just don't want to build a cool looking buggy that ends up being a turd in performance land.
    Thanks.
    Re: engine size
    Jan 2009
    Hey!
    Have you done some research?
    Giorgos has build a ST3 also, with a quite old 750cc engine! It works great as you can see on his movies.
    His topic is in this same group, look it up and read it.
    https://www.minibuggy.net/forum/st3/1...tml#post248218
    Good luck!
    Erwin
    Re: engine size
    I do remember seeing that build. I must have forgotten what size of motor he had used.
    Re: engine size
    Jul 2011
    Larnaca, Cyprus
    hello
    I have used an old 750cc yamaha engine, and with the right gearing the acceleration is great and i can reach 80 mph
    However a newer fuel injected engine 750 cc would kick ass on the st3
    Re: engine size
    Dec 2014
    Airdrie, Alberta
    What horsepower was that 750? Thinking of using a raptor 660 or 700
    Re: engine size
    Quote Originally Posted by cdnjaguar View Post
    A four cylinder 750 should easily make 130-140 hp.
    The Raptor's making 40ish - there's a recent post with a dyno sheet on the 700's output.
    Re: engine size
    Dec 2014
    Airdrie, Alberta
    Oh it's a 4cyl. Starting to thing a raptor engine may not be enough... How would you rug up a reverse gear if one went with a 750 cc 4 cyl?
    Re: engine size
    There are a few options for reverse. The RPM trans is the best, but it's on the pricy side. You can also do the starter/ring gear setup. There are a few guys here running them. I think Glock has it, Yoshi did it, search or wait for someone to pop up and post. Did Mr Bracket have that setup?
  1. Need engine swap help!
    By Dirt400 in forum Projects in Progress
    Last Post: 10-08-2013, 08:02 PM
  2. Adding a oil cooler to Arctic Cat 660 turbo engine
    Last Post: 09-14-2013, 07:13 PM
  3. ZX Engine mounts size dimensions
    By sosasser in forum Motor - Engine
    Last Post: 12-05-2012, 07:50 AM
  4. Rotax 521cc engine package
    By opsled in forum For Sale
    Last Post: 04-21-2012, 06:24 AM
  5. sled engine mounts
    By Stomper in forum Motor - Engine
    Last Post: 03-12-2012, 08:15 PM
