Thread: engine size
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
    Re: engine size
    If you are running trails and dirt roads then 750 has plenty of power if you are planning to play in the sand then more is better.
    Re: engine size
    Sep 2014
    West Palm Beach FL
    Blog Entries
    1
    With the Raptor 700 making about the same amount of torque, but at a much lower RPM make it usable though? Comes with it's own reverse.
    I was in the middle of building a 2 seater fl350 Honda Odyssey with a raptor 660 motor, when I had a chainsaw accident and had to sell it.
    Re: engine size
    Sorry about that. Hope you are ok! did you ever get to drive the buggy? if so was it enough power for the one seater?
    Re: engine size
    Sep 2014
    West Palm Beach FL
    Blog Entries
    1
    Quote Originally Posted by JMperformance View Post
    Started the project with a crashed Raptor and an fl350 rolling chassis, never got to drive either.
    Re: engine size
    Sep 2017
    Lincoln, Nebraska
    If you gear it it deep, it'll work. The website says a minimum of a 600cc engine, but recommends larger. Sport bike engines need to be revved up and not lugging it. So gearing will help a lot. A larger engine will just help get you going and keep you going in challenging terrain.
    Re: engine size
    Would a 60 tooth rear sprocket and the stock motor sprocket on the engine be a good gear ratio for the 100hp and 1000lbs?
  1. Need engine swap help!
    By Dirt400 in forum Projects in Progress
    Last Post: 10-08-2013, 09:02 PM
  2. Adding a oil cooler to Arctic Cat 660 turbo engine
    Last Post: 09-14-2013, 08:13 PM
  3. ZX Engine mounts size dimensions
    By sosasser in forum Motor - Engine
    Last Post: 12-05-2012, 08:50 AM
  4. Rotax 521cc engine package
    By opsled in forum For Sale
    Last Post: 04-21-2012, 07:24 AM
  5. sled engine mounts
    By Stomper in forum Motor - Engine
    Last Post: 03-12-2012, 09:15 PM
