Page 3 of 66 FirstFirst 1 2 3 4 5 13 53 ... LastLast
Results 21 to 30 of 657
    Re: GVouvakos ST3 Build
    #21
    Jul 2011
    Larnaca, Cyprus
    Quote Originally Posted by rob8420 View Post
    It would be easier if you used non-lock nuts on one end and then welded on and spun it on the lathe again it would look better IMO
    Thanks for the suggestion.
    #22
    Jul 2011
    Larnaca, Cyprus
    Today I moved the buggy from my friend's shop in my small warehouse. And also put the front suspension together. Now i need to find out how i am going to mount the shocks.
    #23
    looks great! how much have you spent on the frame so far?
    #24
    Jul 2011
    Larnaca, Cyprus
    I have used metal pipe not tubing so the frame did not cost a lot. But i haven't yet paid for the metal. I believe around 150 euros for the metal and i paid 30 euros for bending
    #25
    REALLY?! thats cheap i got a quote of 120 for all of my 4 tubes
    #26
    Jul 2011
    Larnaca, Cyprus
    Quote Originally Posted by Lknight98 View Post
    As i said i used pipe not tube which is cheaper
    #27
    my pipes were more expensive...
    #28
    Jul 2011
    Larnaca, Cyprus
    I have finally finished the front shock mounts. I could not get 90 degrees at full bump. I believe it's about 70 degrees. I would need to do a lot of modification to get 90. Now i need to find hubs, brake discs and calipers for the front and of-course wheels
    #29
    Jan 2009
    Why did you remove that one bar? It seems on this photo that the future shock will have enough room without removing that bar. Can't you place them both?
    #30
    Jul 2011
    Larnaca, Cyprus
    Quote Originally Posted by ErwinBnl View Post
    No room at all. It would definitely hit at full bump. But in this setup, the shock may hit the upper a-arm. If this happens i will use a limit strap to prevent this and also prevent the steering heim from bottoming
    By leok in forum Barracuda
  3. Kids Kart Build
    By Nobody077 in forum Frame
