Page 16 of 66 FirstFirst ... 6 14 15 16 17 18 26 ... LastLast
Results 151 to 160 of 657
    Re: GVouvakos ST3 Build
    Jul 2011
    Larnaca, Cyprus
    Some update
    • connected the throttle cable, so the throttle pedal is working
    • bought a 530 chain, but it is not heavy duty so i have decided to use double (2 single chains parallel) from the jackshaft to the live axle!
    • tried to weld the splined shaft on my flanges with 316 mig wire, but with no success. So i will go to the lathe shop, and make splined on steel shafts.
    • bought a balance bar to use on my brake pedal
    More to come
    My goal is to have my first test drive before Christmas
    Xmas videos are great. I will have to get one too by Xmas.
    Jul 2011
    Larnaca, Cyprus
    Quote Originally Posted by Chikin1974 View Post
    Don't worry! you will have one
    Jul 2011
    Larnaca, Cyprus
    The last update from the track code of my shocks shows that they are still in Los Angeles
    However, I have started fabricating my gear shifter and bought a car shifter cable to use! Installed the brake balance bar but i have to buy a 3/4 master cylinder for the front brakes.
    Pictures will follow by tomorrow
    Jul 2011
    Larnaca, Cyprus
    looks good keep it up!!!
    Jul 2011
    Larnaca, Cyprus
    Quote Originally Posted by ST4 View Post
    thank you
    Jul 2011
    Larnaca, Cyprus
    I am now designing my dash board to send it for laser cutting.. and i have a question!
    what do you use for a speedometer?? the bikes speedometer is not electronic, it is mechanical with a "wire" going to the front wheel. No way i will get it working on my buggy.. (gps speedometer is not an option).. i need to draw the hole on the dashboard
    that stupid tracking code of my shocks, has not been updated for more than a week
    Tracking numbers suck when your waiting for them. I would make a call tomorrow and make some thing happen.
    Jul 2011
    Larnaca, Cyprus
    box full of stuff got my sprockets machined, the hubs welded and 35mm axle for the jack shaft
    By leok in forum Barracuda
  3. Kids Kart Build
    By Nobody077 in forum Frame
