Thread: St3 shocks
Results 1 to 5 of 5
    St3 shocks
    Jul 2011
    Larnaca, Cyprus
    Hi guys what are the ideal coil over shocks to use with an st3. How long should they be and how thick?
    Re: St3 shocks
    Sep 2010
    Leduc, Alberta, Canada
    ST3/ST2-LT plans show Fox 2.0 series non-coil over Air Shocks. Front = Fox #980-99-013-A (Page E07 of plans), Rear = Fox #980-99-020-A (Page E02 of plans). You can substitute coil over shocks, however, you may have to make adjustments to the shock mounts to allow for the larger diameter body of the springs.
    Re: St3 shocks
    Jul 2011
    Larnaca, Cyprus
    I prefer coil over shocks. Do you thing 19" at the back an 16" at the front will be ok. ?
    Re: St3 shocks
    ??? since the OD of coilover is larger you have to possibly mover the mounts so they will clear arms. You will have to measure for length then using weight at ea corner, and motion rate of arm, determine spring to use.
    Re: St3 shocks
    Probably too late for you but we are using Ford Ranger Air shocks (Autozone) on our ST3's. They are 22.5" eye to eye. You do have to set them up with their own fill valves (rather than using a T) or the buggy will lean a lot in turns. We have had them down to Coal Creek in TN and they worked great. These are on the rear and we have coil overs in front.
  1. Revolution Racing Shocks - New bypass shocks
    Last Post: 08-04-2016, 01:03 PM
  2. Air Shocks
    By ringgo1star in forum Projects in Progress
    Last Post: 11-10-2012, 06:49 AM
  3. One pair Fox Shocks
    By jersdunz in forum For Sale
    Last Post: 05-02-2011, 02:52 PM
  4. How to Check and adjust Nitrogen (air) shocks
    By jersdunz in forum Suspension - Wheels & Tires
    Last Post: 02-16-2011, 09:03 PM
  5. Shocks Questions!
    By elvergonmexicano in forum Suspension - Wheels & Tires
    Last Post: 01-18-2007, 06:18 PM
