Page 1 of 27 1 2 3 11 ... LastLast
Results 1 to 10 of 262
    Sotiris st2 build....!!
    Senior Member sotiris's Avatar
    May 2015
    greece
    hi every one.....
    I am from Greece and I start to build the st2 lt buggy......(my first time to weld and fabricate)
    I have a gsxr k7 1000 engine.....
    I will put yamaha raptor front splines and hubs
    the round tubes I use are (1"named) 33mm od - 2.6mm thick
    and the square tube 40mm x 40mm 3mm thick
    I start with first "floor" frame (square), I made the rear side longer 340mm to put the engine low....! I will see if is very long and I will cut some
    and I bend the tubes to start the second "floor"
    I weld the TA part and TC-TD parts is all welded.....
    but I have one question about TB tubes...... I do not understand the plans (page A07), what mean to" trim" the low area of tube..... where to cut the tubes there?
    I will post pictures soon.....
    (sorry for my poor english language)
    Re: Sotiris st2 build....!!
    May 2015
    greece
    May 2015
    greece
    good luck with the build and keep us posted!
    P.s: ti leei re patrida?!? Xaxax
    May 2015
    greece
    Quote Originally Posted by alex_buggy View Post
    thanks my friend..........I hope I will make that right..!
    p.s. kala file mou, pou vriskese esy?
    Welcome Sotiris.
    I used to work with a guy named Sotiris, Sotiris Vahavilos.
    May 2015
    greece
    Welcome Sotiris.
    I hope this person was good...!!!. Good as the name he carry lol
    May 2015
    greece
    tube notch measure........ home made.....
    maybe will work ...........
    we will see.............
    Jan 2009
    Hey!
    I don't remember all the plans details. I build my chassis approximately 6 years ago. The TB tubes, are that the 2 front tubes where the front suspension will be attached to? You need to notch both the tubes so the TB tubes are in the right angle (I thought it was 10 degrees) and the middle hoop will fit on this in the right place. Measure up the height from the chassis base and the center of the tube. That is a nasty notch with a lot of grinding and trying. Good luck!
    You extended your chassis base with 340mm? That is quite long... remember that the wheel base will be longer, together with your turn radius. Also, the design of your chassis will be different. You need to extend this also or build it different.
    Erwin
    May 2015
    greece
    By leok in forum Barracuda
    Last Post: 09-30-2014, 07:32 PM
    Last Post: 01-11-2011, 01:16 PM
  3. Kids Kart Build
    Last Post: 12-27-2010, 04:38 PM
    By Nobody077 in forum Frame
    Last Post: 09-29-2010, 05:34 AM
    Last Post: 07-06-2007, 12:07 AM
