Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 10 of 119
    ST2 LT Build From Canada
    Dec 2014
    Saskatchewan Canada
    This is probably gonna be a slow build but we'll see what happens. I used 1.5"x.095" wall DOM tubing for the upper frame and 1.5".100" wall sq. tubing for the lower frame. I used 1.25x.120" wall DOM tube for the A-arms. I'm staying pretty close to the plans. I have an idea for Dodge Caravan CV's in the back, but I'm not too far with that yet.
    Re: ST2 LT Build From Canada
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    Wow that looks like a great start, lots of canadians on here lately
    Great Start!!!!!!!!
    Keep Us Updated
    Project X
    Senior Member Duane's Avatar
    Apr 2010
    Santa Rosa California
    Nice work. I was able to view your Photobucket public folder and saw your race mower. Is there a thread on another forum you could link us?
    Dec 2014
    Saskatchewan Canada
    Thanks. I got some of the rear suspension plates welded together today.
    I finished up the suspension bushings and got some bolts for the front A-arms. I'm still waiting for heim joints.
    My plan for the rear axle is to machine two extra wheel hubs down so I have a tube with splines inside and then weld them into a 2" O.D. DOM tube. I've modified some driver side caravan axles to fit outer cv's on both ends and they'll just plug into the DOM with the splined tube welded inside.
    Dec 2014
    Saskatchewan Canada
    Quote Originally Posted by Duane View Post
    Thanks. This is actually my first time posting on a forum, but I've got a bunch of youtube videos under the user Wertheroriginal.
    https://www.youtube.com/user/wertheroriginal/videos
    Dec 2014
    Saskatchewan Canada
    Figured out the back is about 51.5" wide hub face to hub face. The front may be a bit wider but I figure I can even that out with tire and wheel selection.
    Dec 2014
    Airdrie, Alberta
    Awesome! Looking good so far.
    Nice weld on the spool Steve!
    Dec 2014
    Saskatchewan Canada
    Worked on the rear A-arms today.
    This is how I notch the tubes.
    Bushings are a little tight but I figure they'll loosen up on their own.
    It seems to swing through it's motion range nicely.
  1. SS 1000 Canada build
    By ProtoDie in forum SS1000 - Two Seat Race Buggy
    Last Post: 05-12-2014, 01:54 PM
  2. Kids Kart Build
  3. My first build
    By Nobody077 in forum Frame
