Page 2 of 12 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 119
    Re: ST2 LT Build From Canada
    Very nice twists on already great plans. Can I ask how you were able to fab the a-arm jigs? BLB doesn't offer DXF.
    AGAIN, really neat work!
    Looks great Steve! I'm looking forward to seeing more.
    How did you modify the CV shaft to fit 2 outer CVs? Did the splines match up or did you recut some?
    Also, what modifications were required to the suspension geometry for the no-plunge setup with your specific CVs? Were the lengths alright?
    Dec 2014
    Saskatchewan Canada
    Quote Originally Posted by B-Fifty2 View Post
    Thanks. I drew the DXF from the plans. For the past year, up until January when I quit, I ran the waterjet cutting table where I worked. So I cut the front A-arm jig and and the front spindle plates. I really miss having access to the waterjet. I haven't progressed much on the buggy for the past week, but I should be doing quite a bit on it this weekend. I got the shocks and some other parts now. I'm trying to mount the engine which is pretty tight. It's a Suzuki TL1000R.
    Dec 2014
    Saskatchewan Canada
    Quote Originally Posted by Byronnn View Post
    The CV shaft splines were the same, all I had to do was cut a groove for a snap ring so it would click on there. I did some careful measuring and made sure the pivot points of the A-arms lined up exactly with the pivot point of the CV joint. The A-arms are actually an inch longer than the plans call for but the hub setup is more compact and the inner A-arm pivots are closer to the inside so it ends up being about the same as the plans width wise. I kinda wish I had tried to find a little longer axles but this will work ok.
    Dec 2014
    Saskatchewan Canada
    I hung the engine in the chassis. The front mount unbolts from the chassis for removal. I'll tie into the third mount at the bottom when I get the jackshaft plates and add some more bracing to the others.
    I started mounting the front shocks.
    Because I used bigger tube everywhere it was pretty tight to fit the shocks. I also bought the 5.5" shocks instead of the 4.5" the plans call for.
    Dec 2014
    Saskatchewan Canada
    Got the rear shocks mounted. I ended up mounting them vertical.
    I got some hexagonal rings laser cut to weld on the A-arm pivots so the bolts won't turn in the brackets.
    My jack-shaft mocked up.
    Dec 2014
    Saskatchewan Canada
    I got the rear end all together with new chain and CV boots.
    Started on the steering. I got the tie rods done and the rack mount tacked in place.
    That is lookin' good! Really like that you went with a no plunge set up.
    Dune 500
    Dec 2014
    Saskatchewan Canada
    Thanks. I can't wait to get this thing on it's wheels.
    Dec 2014
    Saskatchewan Canada
    This week I got the steering all together.
    I ended up using one u-joint from a Geo Metro cause I didn't order enough of those weld in splined stubs.
    The wheel adapters I ordered for the rear were only 20mm thick instead of the 50mm I wanted, a little miscommunication I guess. So I had some spacers waterjet cut out of 1" aluminum. After machining they ended being 9/16" of an inch thick. It ends up being 2 inches narrower in the rear, which is ok.
    Finally set this thing down on it's wheels. It looks pretty awesome I think.
    When I went to ask about prices on tires at a local shop, I asked if he had any used tires and he gave me this set for free. 26x9-14 in front and 26x11-14 in the rear. They don't even seem to leak or anything.
  1. SS 1000 Canada build
    By ProtoDie in forum SS1000 - Two Seat Race Buggy
    Last Post: 05-12-2014, 01:54 PM
  2. Kids Kart Build
  3. My first build
    By Nobody077 in forum Frame
