Results 31 to 38 of 38
    Re: ST 2 Long Travel Buggy
    #31
    Rear end pic's
    These are the only ones I have
    #32
    Try again
    #33
    Last one
    #34
    Does the exhaust pipe stick out underneath the frame? Aren't you worried about flattening the pipe when you bottom out?
    #35
    Hey wiKisi,
    No not worried about bottoming out, the lowest point in the design is the sprocket, the exhaust runs parallel to it. There is a skid plate the full length under the rear to protect the sprocket and exhaust both are protected.
    Not ideal but necessary with this type of design using a center spool.
    Have fun,
    Ted
    #36
    have any problems with overheating? MHO the rad should be mounted higher up to get some air flow.
    #37
    Jul 2011
    Larnaca, Cyprus
    Nice looking so far!! keep it up
    #38
    That looks slot longer than mine behind the seat
    Looks good though
    Have to get mine dug outa the corner and figure this out
  1. Long Travel Suspension Design
    By DieselTwitch in forum Suspension - Wheels & Tires
    Last Post: 12-25-2012, 02:39 PM
  2. R1 Long Travel Rail
    By clayh88 in forum For Sale
    Last Post: 08-13-2012, 04:39 PM
  3. improving the turning of an ATVR long travel Pilot
    By odypilots in forum Honda's Pilot & Odyssey
    Last Post: 04-25-2011, 04:06 PM
  4. Badland Buggy ST2 Long Travel Suspension brain storming.
    By Glock n Ballz in forum Suspension - Wheels & Tires
    Last Post: 02-15-2010, 03:07 PM
  5. 05 Rhino with Long Travel, Cage, Paint, etc. $11,000.00 *****
    By PlaySomeSkynyrdMan in forum The UTV Area
    Last Post: 08-13-2009, 04:58 PM
