Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
    Re: Badland ST2 custom build from Ireland
    #21
    cool nice tires
    #22
    May 2013
    Cootehill ireland
    Made almost no progress this last few weeks I did manage to get the rear diff set into my frame
    I had go cut away some of the rear tubes I had fitted as I want to lower the front side of my wishbone diff mounting plates to get my engine lower
    This will mean my wishbones won't be parallel with the ground not ideal but it will work
    I'm also gonna bend new tubes for the top and bottom of the rear frame to suit this new idea it will change the look of the rear end but for the better I think
    #23
    Jan 2009
    Hey!
    Nice to see that I have inspired you to build a ST2 LT too!
    I'm also using tube/pipe with a welded seam, it must be strong enough.. I think
    Watch out with the rear shock mounts of the buggy! I'm going to change that too. As you maybe have read on my threat.
    Keep us posted! I'm very curious about your build. You are going fast! Making big progress.
    #24
    May 2013
    Cootehill ireland
    I was one of those who suggested you move your shocks so I'm definatley moving placing mine in line with the travel
    Feels and looks like nothing is happening these days
    Bought a tractor too so working on that at the minute
    #25
    Jan 2009
    Oh yeah of course! Thanks
    I didn't see it was you.. the same guy.
    May I ask where you bought the bender? Did you do that online?
    #26
    Jul 2011
    Larnaca, Cyprus
    Looks good so far!
    A small suggestion from me, if you are going to use fox air shocks, the plans say 4" travel shock for the front but they are not long enough if you are willing for long travel in the front.. You can easily modify to fit longer shocks thus more travel
    #27
    Mini-Raptor Body Man
    Jun 2012
    Ireland/Wisconsin
    Quote Originally Posted by monkeyinfantry View Post
    If i'm not mistaken, you're not supposed to use pipe because its designed to hold pressure in and carry liquids, not hold up to physical hits, aka, it will fold like a paperclip in an accident
    Just to clarify, he IS using what we (USA) call mild steel DOM tubing...AKA, pipe--in Ireland There are a million little, confusion causing, differences in terminology between the US and EU...but that's all it is...terminology. It took me years, and just when I think there can't be anything else, I hear something new. Anyway, it's looking good, proceed sir...
    BTW, we have a place in Mayo; my better half is a Galway girl.
    #28
    May 2013
    Cootehill ireland
    Thanks for clearing up that tube pipe thing
    Galway and mayo are lovely places but I don't get over there too often unfortunately
    #29
    Senior Member MrBracket's Avatar
    Aug 2009
    Eugene, Oregon
    Quote Originally Posted by Nivek4209 View Post
    Rear drive train is going to have a limited slip diff I made up from a impreza wrx rear LSD
    It was incorporated into the original wishbone mounts from the badland plans and will have twin in board disc brakes when complete I'm using the std r160 shafts and cut down rear impreza hubs too
    This is why I may end up loosing some suspension travel I'm unsure as yet how much angle these drives can take but I'm hoping around 14 " + or --
    Hi Kevin,
    I'd love to see more about this drive setup you've created. Please elaborate if possible. Thanks in advance,
    Mike
  1. ST4 build - new to minibuggy
    By Benjammin1414 in forum ST4
    Last Post: 01-09-2014, 05:21 AM
  2. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 09:24 AM
  3. Ready to start a build
    By Snoopy in forum MiniBuggy.net Lounge!
    Last Post: 07-26-2012, 05:29 AM
  4. Custom Buggy Build
    By Eoxan in forum Projects in Progress
    Last Post: 05-19-2012, 12:56 PM
  5. Love for the Build
    By AtvNut in forum How To Do It
    Last Post: 10-04-2010, 07:52 AM
