Results 11 to 20 of 29
    Re: Badland ST2 custom build from Ireland
    Senior Member monkeyinfantry's Avatar
    Sep 2012
    Howell, MI
    "For the main chassis frame, we recommend you use what is called Hollow Structural Round Tube"
    My Protodie SS1000 Build
    My 1980 SR250 Build
    My 1999 Blaster Build
    2016 YZ450F
    2006 YZ450F
    2013 KLX110 stockmod
    May 2013
    Cootehill ireland
    I think the lines have been blurred a little to much here the terminology between us suppliers and European tube pipe suppliers don't really tally
    I took that page with me to two different suppliers when buying my steel the only thing that matched it perfectly dimensionally and in description with the welded seam in mild steel as described in the previous post is what is commonly known in ireland as inch gun barrel this is not a poor quality light wall piping that you would make a cheap farm gate from
    I'm happy with its quality s and yes it could be made from better stronger safer lighter stuff but this ain't NASA and all that piping tubing I bought cost 120€ so it didn't exactly break the bank
    Next time maybe we will experiment with other materials but for now I'm happy I got what was described
    May 2013
    Cootehill ireland
    Done a little mock up with my back diff and the first outer hub I have ready there this evening
    Its giving me an overall rear width hub face to face of 1.5 meters or 5 ft is this average
    Also can get 14 inches of suspension travel each side without stressing the drives 16 is possible but at its limits
    May 2013
    Louisiana
    Great job! I am currently building the Cheetah from Buggy Innovations, I'm using D.O.M. tubing on my chassis. Maybe one day I'll learn how to use a lathe lol.
    looks like your phone is all most dead i hate that
    May 2013
    Cootehill ireland
    You've lost me ??
    so am i and i am the one who said it
    May 2013
    Battle Ground, WA
    That pdf has it wrong.. Tube is OD, Pipe is measure ID.
    Trying to find time to finish that buggy...
    May 2013
    Cootehill ireland
    Well after being banned by mistake for the last few weeks I have managed to get admin to put me back online
    Quite annoying at the time I must admit
    May 2013
    Cootehill ireland
    A little progress has been made
    My lathe is off limits at the moment the motor has noisy bearings so I have a new one ordered to sort that it arrived today but not fitted yet
    Got wheel centres sorted out as I'm using impreza 5x100 rear hubs and banshee quad front hubs at
    4 x x156 pcd
    Just got 4 plasma cut to suit
    Well weld in and centre on a bigger lathe than mine
    Also the banshee front spindles/ hubs have cured the problem of no front brakes in the st2 plans
  1. ST4 build - new to minibuggy
    By Benjammin1414 in forum ST4
    Last Post: 01-09-2014, 05:21 AM
  2. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 09:24 AM
  3. Ready to start a build
    By Snoopy in forum MiniBuggy.net Lounge!
    Last Post: 07-26-2012, 05:29 AM
  4. Custom Buggy Build
    By Eoxan in forum Projects in Progress
    Last Post: 05-19-2012, 12:56 PM
  5. Love for the Build
    By AtvNut in forum How To Do It
    Last Post: 10-04-2010, 07:52 AM
