Results 11 to 20 of 22
    Re: New member from Ireland building an st2 gsxr 750 k5
    yeah like the tires they look cool
    Member sqweeker's Avatar
    May 2010
    Tonawanda NY
    Nivek,
    A couple of suggestions for you before you get to far check the clearance for your head, the ST2 stock frame does not have much/enough clearance unless you're not to tall.
    The front lower A-arms, you may want to add extra support or make them with a truss design, otherwise they bend very easily at the shock mount area, the tops are fine just the lowers have issues. At least mine did.
    If you didn't plan on it try and add front brakes, the plans don't have any, but believe me it is well worth the effort when you need to stop in a hurry.
    Good luck,
    They are fun to drive
    May 2013
    Cootehill ireland
    I'm planning on adding front brakes and am making a few changes as I go along there is a support in the plans on the front wishbone but it looks rough so I will do better
    I'm getting rid of the single pin keeping ghe wishbones on front and rear and doubling up on the brackets and bushing s using bolts instead
    More pics will follow soon
    Good to see theres a few of us paddys on the website ! Shes looking well so far,what is the diff out of ?
    May 2013
    Cootehill ireland
    Impreza wrx rear diff and shafts
    Where ya from ??
    I'm. Cootehill Cavan
    Jan 2009
    Hey!
    Nice to see another ST2 build!
    I have front disk brakes also, I just used the front stub axles, wheel hubs, calipers and disc brake plates from The Edge.. and build it into the ST2 LT design.
    Keep us updated!
    Erwin
    May 2013
    Cootehill ireland
    Hi Erwin
    I have watched your YouTube videos with great interest land I think it was one of them that led me here
    Are you up and running yet
    I havnt found your thread on here as yet
    Sep 2012
    Canada
    Quote Originally Posted by Nivek4209 View Post
    Just started really have top section according to the plan in the pic but have decided to stray away from the plan and build the full frame in round tubing
    Also have added a rear LSD which I have completed with inboard disc brakes
    Have wheels and tyres 26 x 10 x12 rears ans similar 8" fronts
    Mini rail quick rack arrived from sand parts last week
    Gsxr 750 k5 has been mine for a long time in waiting for this build
    Have rear gaz coilovers 12" stroke but no decent fronts as yet
    Looks sweet dude! I'm just wondering, What center housing unit is that? Or did you make it your self, if so what did it cost to build? What size/kind of tubing are you using?
    Good clean look to it
    May 2013
    Cootehill ireland
    Quote Originally Posted by Fred3500 View Post
    It's badlands plates with impreza diff and shafts hubs inboard brakes mounted on collars I added to the inner cv joints
    Diff is sealed up with a cap and will be using grease instead of oil
    Sprocket adapter made to suit crownwheel bolts and sprocket
    Most expensive thing in it so far was two bearings at 40 euro I had the diff in a swap with a mate for other stuff and the adapters I made at work before I got my own lathe
    If ya bought everything probaly 300 would cover all
    i bet it is 1inch that whats the plans call for
  1. GSXR Powered MiniLite
    By skreikem in forum Projects in Progress
    Last Post: 11-23-2015, 04:47 PM
  2. Trade: Turbo gsxr 1000cc powered raptor
    By brandon1566 in forum For Sale
    Last Post: 03-21-2012, 04:26 PM
  3. single seat GSXR 600
    By clayh88 in forum For Sale
    Last Post: 07-12-2010, 12:46 PM
  4. GSXR Triple-E
    By ReckONE in forum Projects in Progress
    Last Post: 03-10-2010, 02:24 PM
  5. Protodie GSXR 1000 new air box
    By ProtoDie in forum Motor - Engine
    Last Post: 12-12-2009, 09:06 AM
