Yep, I’m in Utah. It was at little Moab. There are some really fun twisty trails to get sideways on out there. Send me a message and we can exchange contact info if you ever want to meet up.
Thread: Godfather's SS1000 Protolite
Results 31 to 39 of 39
- Join Date
- Jul 2020
- Posts
- 25
12-30-2020 04:21 PM
- Join Date
- Jan 2010
- Location
- Maricopa, AZ Trailhead is right outside my front door
- Posts
- 322
12-31-2020 01:56 AM
I will be relocating to the Phoenix area next year. Work will have me covering all of the Western states CA, OR, WA, ID, MT, UT, NV, AZ, NM, WY and CO. It would be great if we can connect at some point during my travels. I know you have listed your buggy for sale, but I am sure we can figure something out along the way.
CWI CWS CWE
- Join Date
- Jul 2020
- Posts
- 25
01-25-2021 10:11 PM
For sure, let me know when you’re in Utah. Chances are I’ll still have it and if not, it will be a single seater buggy at that point so I’ll always have something.
- Join Date
- Jul 2020
- Posts
- 25
01-28-2021 04:36 PM
Absolutely man, lets do it. Moab might be interesting depending on how certain policies plan out. Some are trying to get UTV's kicked out of certain areas but i'll keep you in the loop.
Kfab, I know I messaged you before on this but i'm wanting to pull the trigger on some coilovers and want to make sure I have specs down correctly. The buggy is currently in storage or else I would go take measurements and send it to accutune.
So, I think i'm going fox coilovers with remote resevoir front and rear (unless there is a reason I should go piggy back instead. Would like insight). The buggy will mostly be used for more higher speed hill course racing (colorado hill climb, stage rally, etc) and some light road coarse usage.
Looking at Fox site, I am looking at the following:
Front
Factory Race 2.0 x 12.0 Coilover Remote Shock with DSC Adjustment. Shaft =7/8, extension 31.1, compression 19.1, Reservoir 2.1 x 11, Mounting 1/2 x 1.25 Valving 50/70
Rear
Factory Race 2.0 x 16 Coilover Remote Shock with DSC adjustment. Shaft = 7/8, extension 40.1, Compression 24.1, Resevoir 2.0 x 11, 1/2 x 1.25, Valving 50/70
Does this setup look correct for the SS1000? Can anyone give me input on what springs would be recommended? I'm thinking along the lines of dual rate eibach
- Join Date
- Jan 2010
- Location
- Posts
- 322
01-28-2021 04:59 PM
I know this wasn't addressed to me, but since you messaged me before I thought I would chime in... Unless you are going to completely redesign all your suspension, where is that much shock going to fit??? They were only designed to have a FOX 10" 2.0 Air shock that has the following spec's
- Product Collapsed Length: 17.43"
- Product Extended Length: 27.43"
- Even if the rears were a 12" air those spec's are :
- Product Collapsed Length: 19.33"
- Product Extended Length: 31.33"
There isn't much room in the back for shock expansion. I know I had to cut my rear lower brace to my Elka Coilovers to fit and I followed the stock specifications as much as possible.Marine Veteran Sgt USMC 8151/8541 1992-2000
CWI CWS CWE
- Join Date
- Jul 2020
- Posts
- 25
01-28-2021 05:38 PM
Sorry, I got things mixed up while trying the multi task, I think these are the correct ones i'm looking at
Fox Factory Race 2.0 x 10 piggy back. 5/8 Shaft, 26.64 Extension, 16..67 Compressed, Mounting 1/2 x 1.25 Valving ???? I'm thinking 50/70?
I dont see any issue running piggy back in the rears, but looking at the front, i'm not sure if there is enough room to accommodate for the piggy back reservoir hence the thought I might have to go remote.
- Join Date
- Jan 2010
- Location
- Posts
- 322
01-28-2021 06:04 PM
Got ya, just trying to be sure you get the correct ones since it is an expensive enough hobby, without any extra mix ups. One other thing to check is front coil clearance and spacing on the lower eyelet, I know there is a pretty extreme angle at full droop and you might need a longer eyelet to clear the bottom coil carrier. You are correct, you will probably need to go to a remote reservoir. I did manage a pair of piggy backs, but all of my stuff is one off because the suspension components weren't being made anymore.
CWI CWS CWE
- Join Date
- Jul 2020
- Posts
- 25
01-29-2021 06:01 PM
In case anyone is wondering on fox part numbers, here is what Fox gave me after being on the phone for a bit.
Part number is 980-02-005-1 with longer eyelet. Fox remote res coilover 2.0 x 10 with 5/8th shaft. Factory valving is 40/60 which I think will be ideal given the weight. Now to figure out springs.
ProtoDie SS1000 build
By kustomfab2003 in forum Projects in ProgressReplies: 152Last Post: 12-21-2022, 05:56 PM -
Basic Protolite SS1000 Frame Build
By bryzoe in forum SS1000 - Two Seat Race BuggyReplies: 267Last Post: 06-27-2018, 04:27 AM -
Protolite SS1000 -Outlaw UTV
By ProtoDie in forum SS1000 - Two Seat Race BuggyReplies: 49Last Post: 03-06-2014, 05:50 AM -
By chickenwings_85 in forum For SaleReplies: 15Last Post: 09-23-2012, 09:50 AM -
2 seat 1000cc buggy for sale -Protolite SS1000
By ProtoDie in forum For SaleReplies: 9Last Post: 09-13-2012, 08:04 PM
