Page 2 of 15 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 147
    Re: ProtoLite SS 1000-new 2 seat build
    S.W. Michigan
    Thanks Justin,
    I decided to wait until after I get laser to pull it off the jig table.
    This way I can build the engine cradle, and weld in all the mounts right on the jig.
    That means I will go to steering, seat mounts, and make a few A arms instead.
    Senior Member el diablo's Avatar
    Dec 2008
    Mojave Desert, Ca
    Looks great, I love the look and design of your cars. Can't wait to see some video of it tearing it up!!
    I'm not totally useless, I can be used as a bad example!!
    S.W. Michigan
    Thanks alot,,,,,I am looking forward to make some video with this one.
    I just got my seats, calipers, window nets, master cylinders, brake lines,,,etc,etc......
    I will mount the seats 1st , then steering.
    looking great so far!
    cant wait to see it running
    S.W. Michigan
    Allright,,,,,things are rolling good.
    seats are mounted. I use 1 5/8 Unistrut, so that the seats can be adjusted,,,then locked down.
    Much stronger than seat sliders, but take a few minutes to adjust.
    Wilwood brake / clutch pedal assembly is in,,,gas pedal, as is the steering with a quick disconnect.
    I must say,,I am very happy with the fit & feel of all the pedals, steering wheel and seat.
    The other cars have been very good & comfortable, but the little things I changed from other builds makes this one feel great & fit like an almost worn out work glove,,,,perfect.
    S.W. Michigan
    few more
    Jan 2009
    Wow what a good and fast progress you make in a couple of days!
    Great build to follow, thanks for all the pictures.. You already catch up my build wich now takes a year But you can't compare those two builds because you are a buggy guru, and i'm a buggy dummy
    Have fun and good luck with your build! I will follow it with pleasure
    S.W. Michigan
    Thanks, for the kind words.
    Every build gets faster & easier,,,for most everyone
    While it looks fast, I spend MANY hours engineering & designing before the build so that when it is time ,,,all the problems are worked out, parts are sourced and I just need to grab numbers & prints and build it.
    Years back,,the builds took alot longer because we were sourcing parts, designing,,,,,testing,,,,,debating,,,,changing our mind,,,sourcing parts,,,designing,,,testing,,,,the endless cycle.
    Now many of the parts we designed and make,,so I can get them off the shelf instead of waiting a few weeks.
    Bend, OR.
    Beautiful as usual..
    Like the use of the Heim for the steering column support.
    Are you going to add any sort of V or diagonal brace behind the seating area? That's the only thing that catches my eye as something for you to consider (something to resist lateral loads a bit more).
    Very nice!!
    S.W. Michigan
    That is a 5/8 heims, and you have to turn the tubing down just a touch.
    This lets you adjust the point if needed.
    I have a bunch of tubes I am adding yet,,,,especially side bracing.
    Not sure which area you are refering to, but the thing to remember is we are and have been using 1 1/2" dia tubing, and not 1 1/4"
    I have taken some of the early cars for sprint car tumbles and they always prove over built.
  1. Replies: 110
  2. ProtoDie DXT 1000 single seat racer
    Last Post: 10-07-2010, 07:03 PM
  3. ProtoDie 2 seat mini buggy- next build
    Last Post: 09-01-2010, 07:12 PM
  4. new mini buggy 2 and 4 seat build
    By fusionoffroad in forum MiniBuggy.net Lounge!
    Last Post: 01-21-2010, 12:37 PM
  5. ProtoDie- ProtoLite 1000 single seat racer
    Last Post: 11-27-2009, 08:25 PM
