Results 1 to 6 of 6
    Steering and gearing
    I was wondering if anyone had figured out a way to reduce the amount of pushing the buggy does in a turn at slow speeds I'm trying to reduce the turning radius without sliding rear end around. Also I'm looking to run 29 in tires and was wondering if any of you guys had a gearing setup figured out last question I would like to upgrade the clutch in busa to handle 29 in tires in a woods riding scenario I prefer low gears thanks for all the input.
    Re: Steering and gearing
    Quote Originally Posted by Abgreen10 View Post
    To get rid of the Push you need a diff in the rear
    I run 31" tires on mine and clutch mod is a 4.5mm alloy spacers ( 6 off) under the clutch springs = more clamp pressure , But will also end up cracking your cover the clutch slave is mounted in so Upgrade kit would ne advised
    APE Clutch Slave Support Bracket Suzuki GSX1300R Hayabusa (99-07)
    Sep 2013
    Turning brakes on the front maybe?
    A diff is the only real way to stop the back from pushing in a low speed tight turn.
    Jan 2009
    Los Angeles
    Give it has and Drift the rear!
    Sep 2006
    Groves, Texas
    You can check/fix the steering for correct ackerman, bump steer and enough turn angle. This will help but nothing will work as well as a differental.
    Correcting the ackerman on my barracuda helped the slow speed stuff considerably. There was little slip when I was idling around, unless the pavement was covered in sand. If your ackerman isnt correct, one of the front tires always slips, reducing your traction on the front end.
    Weight distribution plays a big role as well.
  1. Slow Build by Engineer
    By Engineer in forum Projects in Progress
    Last Post: 07-26-2016, 03:37 PM
  2. How to figure MPH based with gearing?
    By frankysfree in forum Suspension - Wheels & Tires
    Last Post: 02-06-2012, 06:50 PM
  3. ST4 Steering Rack Questions
    By 6x6TRex in forum Controls and electrical
    Last Post: 11-03-2010, 01:39 PM
  4. Gearing help
    By bud4598 in forum Driveline
    Last Post: 09-20-2009, 09:21 PM
  5. gearing for desert
    By Boyd in forum Driveline
    Last Post: 07-13-2006, 02:16 AM
